This page provides information about the Team render tab in the Render settings window.
The options available in this tab will allow you to adjust the Team Render functionality when distributing rendering jobs across the network.
UI Path: ||Render settings window|| > Corona > Team Render tab
Distributed rendering using Team Render will only work if you first enable the use of Team Render in the Cinema 4D's preferences.
(menu Edit > Preferences > Renderer > Team Render)
Team render
Configuration – Allows selecting the Team Render's functionality, whether if it will be Automatic or Manual.
Available configuration modes are:
Manual – Allows you to manually set the Client update interval and the Maximum size of packet values.
Automatic – Automatically adjusts the Client update interval and the Maximum size of packet values.
Arbitrated (experimental) – This is an experimental mode.
Client update interval [s] – Sets the time interval in seconds to communicate with Team Render clients across the network.
Maximum size of packet [MB] – Defines each information packet's maximum size that will be sent to the Team Render clients across the network.
