This page provides details on the V-Ray Toon Lighting Render Element.
The Toon Lighting Render Element stores direct lighting information from lights in the scene and VRayToonMtl as lit by the scene's lighting. This render element can be used to brighten, lessen, or tint the direct lighting in a composite without affecting indirect light or reflections, for example.
The Toon Lighting RE is included in the Lighting RE. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||Display Render Settings button|| > Render Elements tab > Toon Lighting
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
Attributes
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file.
Apply color mapping – Applies the color mapping options specified in the Color Management rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
