Official Release
Date – 18 May, 2023
Release Notes: V-Ray 6
V-Ray 6, update 1 is here
Check out all the amazing new features that will help you improve your renders.
Chaos Scatter
Powerful instancing and distribution tool that allows you to easily populate scenes. Finetune the distribution to get the perfect result.
Bump to Glossiness Map
Generates the correct glossiness/roughness levels, based on a normal map input. This produces the correct glossiness for normal-mapped surfaces at any distance, while preserving detail.
Light Decay
Control light intensity over a distance. Fine-tune light hotspots, control the spread and length of the light rays and adjust the final look of your lights.
Enhanced Procedural Clouds
Make your clouds more realistic by adjusting how dark they are, randomizing them, or incorporating contrails.
VFB Improvements
Improvements to the Lens Effects, Light Mix and Denoiser functions inside the VFB for easy and fast post-production.
USD Improvements
Greater Maya USD version support, as well as V-Ray Render Elements support.
NVIDIA AI Denoiser upscaling
Up to 4 times faster rendering with the new Upscaling option in the NVIDIA AI Denoiser. Perfect for previews.
Support for Maya 2024 and Apple Silicon
Edit emissive V-Ray Materials in V-Ray Light Mix
V-Ray Clipper Mesh Mode
