Version 1 Current »
This page provides information on the Source Panel in the Property Panel.
Page Contents
The Source Panel is part of Pdplayer's Property Panel and allows you to view custom layers in .exr and .vrimg files.
UI Path: ||Property Panel|| > Source panel
Properties
Image Layer – Allows you to view custom layers (other than RGB, Alpha, Luma and Z-Depth) inside .vrimg and .exr files. You can either flip through the layers by clicking on the Previous and Next buttons or you can right click and select a layer from the drop down menu. Switching between the different layers causes the image to be reloaded which may cause a small delay. For more information, see the Image Layers example below.
Channels – Allows you to display different channels of the current layer. You can either flip through the different channels or right click and select a channel from the drop down menu. For more information, see the Channels example below.
Version – This field is enabled when Pdplayer detects that you have loaded a sequence which has several versions. It will detect certain key words in the file path and find the other versions automatically. You can then cycle through the versions with the Previous and Next buttons or right click and choose from the drop down menu. For more information, see the Versioned Footage example below.
Target View – Select a target for the current layer when using the Stereoscopy feature of Pdplayer. You can either scroll through the options or right click and choose from the drop down menu.
Example: Image Layers
Different layers of an EXR file
The following image shows a composition in which a single EXR file with render elements has been split into layers. On the left we can see the RGB part of the image. The left image is created by composing the render elements together using the Add operator. It is clearly visible that the two images look the same. However using render elements allows for much more control when applying color corrections for example.
Open EXR with Render Elements
Example: Channels
The Channels field allows you to display different channels of the current layer. You can either flip through the different channels or right click and select a channel from the drop down menu.
Different channels of an image
Example: Versioned Footage
Pdplayer will recognize versioned footage when the file path contains a directory with a name of the form prefix_v#_suffix, where prefix and suffix are arbitrary strings, and # is a sequence of digits. The prefix_ and _suffix parts are optional. Examples of versioned directory names: v2, V004, v04_before_cc, animation_v05, scene_v2_2009_05_31.The version string is automatically replaced in the file name, if present.
Examples of versioned footage:
Example 1
D:\shot08\scene_15\v02\bg\bg_v02_0001.tga
D:\shot08\scene_15\v03\bg\bg_v03_0001.tga
Example 2
C:\projects\promo\v2_before_cc\0001.tga
C:\projects\promo\v3_after_cc\0001.tga
Example 3
X:\Footage\conv\V002_2009_05_27\conv_proxy_h264.mov
X:\Footage\conv\V003_2009_05_31\conv_proxy_h264.mov
Example 4
D:\shot08\scene15_v2\bg\shot08_scene15_v2_bg_0001.tga
D:\shot08\scene15_v3\bg\shot08_scene15_v3_bg_0001.tga
Example 5
C:\projects\promo_v2_before_cc\v2_0001.tga
C:\projects\promo_v3_after_cc\v3_0001.tga
Example 6
X:\Footage\conv\V002_2009_05_27\conv_V002_proxy_h264.mov
X:\Footage\conv\V003_2009_05_31\conv_V003_proxy_h264.mov
