© Taichi Kobayashi
« Previous Version 7 Next »
This page provides information on how V-Ray options are integrated into the Houdini menus.
V-Ray adds a number of commonly used V-Ray components to Houdini's main menu. From these options, you can manage Render, Object, and Displacement properties; import files; and manage VFB and V-Ray IPR.
V-Ray menu
Render menu
MenuDescription
RenderSelects a V-Ray ROP from a dropdown menu and starts rendering.
Render SettingsSelects a V-Ray ROP from a dropdown menu and opens its V-Ray Render Settings.
Show VFBOpens the V-Ray Frame Buffer.
Light ListerOpens the V-Ray Light Lister dialog.
SettingsOpens the Settings submenu.
Object PropertiesOpens the Object Properties submenu.
ImportOpens the Import submenu.
Pack SceneOpens the Report Bug/RFE dialog.
chaos.com
Opens Chaos website.
HelpOpens the Help submenu.
About V-RayShows you information about the installed version.
MenuDescription
Global SettingsOpens the V-Ray: Global Settings window.
UIOpens the UI submenu, containing Reset Log Window and Reset Light Lister Window options.
MenuDescription
CommonOpens the Object Properties tab.
DisplacementOpens the Displacement tab.
HairOpens the Hair tab.
CameraOpens the Camera Properties tab.
Physical CameraOpens the Physical Camera Properties tab.
Remove V-Ray PropertiesRemoves all V-Ray Properties assigned to the selected object.
Menu
Description
Chaos CosmosOpens Chaos Cosmos Browser.
Material (.vrscene)Imports a material from a .vrscene file.
AUR Cache (.aur)Imports an .aur cache file (a Phoenix simulation cache file).
MenuDescription
DocumentationOpens the V-Ray for Houdini online documentation.
TutorialsOpens the Tutorials page of the V-Ray for Houdini online documentation.
ForumOpens the V-Ray for Houdini forum.
MenuDescription
Create Render NodeCreates a V-Ray Renderer node as well as a V-Ray Renderer IPR node.
Edit Render NodeOpens a list of existing V-Ray Renderer and V-Ray Renderer IPR nodes. When you click on a given node, its ROP parameters are displayed for edition.
