Square Enix © Goodbye Kansas
Version 1 Current »
Official Release
Date – 18 May, 2023
Release Notes: V-Ray 6
Download V-Ray for Maya
V-Ray 6, update 1 is here
Check out all the amazing new features that will help you improve your renders.
Chaos Scatter
Powerful instancing and distribution tool that allows you to easily populate scenes. Finetune the distribution to get the perfect result.
Learn more
Bump to Glossiness Map
Generates the correct glossiness/roughness levels, based on a normal map input. This produces the correct glossiness for normal-mapped surfaces at any distance, while preserving detail.
Learn more
Light Decay
Control light intensity over a distance. Fine-tune light hotspots, control the spread and length of the light rays and adjust the final look of your lights.
Learn more
Enhanced Procedural Clouds
Make your clouds more realistic by adjusting how dark they are, randomizing them, or incorporating contrails.
Learn more
VFB Improvements
Improvements to the Lens Effects, Light Mix and Denoiser functions inside the VFB for easy and fast post-production.
Learn more
USD Improvements
Greater Maya USD version support, as well as V-Ray Render Elements support.
Learn more
Improved Profiler
Get more detailed reports on your renders and improve your workflow.
Learn more
NVIDIA AI Denoiser upscaling
Up to 4 times faster rendering with the new Upscaling option in the NVIDIA AI Denoiser. Perfect for previews.
Learn more
GPU Improvements
Render faster using the new Compressed texture mode.
Learn more
Support for Maya 2024 and Apple Silicon
Learn more
 Edit emissive V-Ray Materials in V-Ray Light Mix
Learn more
 V-Ray Clipper Mesh Mode
Learn more
