Square Enix © Goodbye Kansas
« Previous Version 5 Next »
The Self Illumination Render Element stores the illumination of any self-illuminated materials in the scene.
The Self Illumination Render Element isolates self-illuminated materials, including V-Ray Mesh Lights, objects with the VRayLightMtl, and any objects with Self-Illumination enabled in their V-Ray material. This render element is useful for brightening or color-correcting self-illuminated materials in the final composite.
For example, the material VRayMtl has a parameter for self-illumination. If this parameter is set to a non-black color value, this render element will show the results of the self-illumination.
UI Path: ||Display Render Settings button|| > Render Elements tab > Self Illumination
Render (menu) > Render Settings > Self Illumination
Attributes
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.selfIllum.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Common uses
The Self Illumination Render Element is useful for changing the appearance of self-illuminated surfaces after rendering in compositing or image editing software. Below are two examples of its use.
Original Beauty Composite
Self Illumination Render Element with added glow
Tinted Self Illumination Render Element with added glow
Self Illumination with added glow
Color of self-illuminated surface changed in composite
Compositing Formula
vrayRE_Self_Illumination + Beauty = Final Image
  • This element contains only the light geometry itself, not the light emitted from it. Lighting information is contained in the Lighting Render Elements.
