« Previous Version 32 Next »
Chaos Vantage , v1.4.2
Official Release
Date - July 21st, 2021
New Features
Camera
Output
  • Support for saving EXR (16-bit) images - the main image is linear, without color corrections and post-effects. Available channels: Bumped Normals, Depth, Screen Velocity, Albedo, Additional (Background & Lights)
Materials
  • Basic support for the V-Ray Car Paint 2 Material
Modified
Materials
  • Improve support for the V-Ray Car Paint Material
Fixes
Output
  • Light gizmos are rendered in final sequence
  • Chaos Vantage renders different frame number compared to Max
  • Chaos Vantage renders 1 frame less than the full timeline
Animation editor
  • Animation timeline cannot display more than 1 transient clips on the right
  • Cannot select transient clip on the right of the timeline
Vantage file
  • Can't save vantage file when path contains non-Latin characters
Crash
  • Crash on app launch with external GPUs
Chaos Vantage , v1.4.1
Official Release
Date - July 2nd, 2021
New Features
Textures
  • Support for Substance textures
  • Support for SketchUp native textures and colorization
UX
Geometry
  • Support for animated object visibility from a .vrscene file
Modified
UX
  • Improved snapping and transforms windows:
    • Added 'S' as shortcut to toggle snap on/off
    • Don't hide the dialogue when exiting free look mode and the window has been opened beforehand
    • Spinboxes display scene units
  • Improved Offline render UI:
    • Added resolution preset
    • Added aspect ratio control
Geometry
  • Support for Edge boundary checking in Forest Pack
Tools
  • Support for importing camera parameters(static and animated) with 'Import changes from Vantage' tool in 3ds Max
  • Imported cameras are now named [VANTAGE FILE NAME]_[CAMERA NAME]_###
Fixes
Camera
  • Auto vertical tilt doesn't keep vertical lines in camera transitions
  • Camera rolls while transitioning between two upright positions
UX
  • Collision detection regression
  • "Orbit" and "Look around" navigation are uncontrollable when on second monitor and >150% dpi scale
  • Scene up vector is not applied correctly to merged .vrscenes/cosmos assets
Materials
  • 2-Sided material doesn't work correctly in SketchUp/Rhino/Revit/Cinema4D
Textures
  • Crash with TexMulti when it has an unsupported sub-texture connected to it
  • Vantage doesn't match V-Ray when TexMulti has an empty textures list and random hue/sat/gamma
Tools
  • "Overwrite existing" in "Import changes from Vantage" doesn't work for Chaos Vantage animated camera
  • Camera Interpolations imported with "Import changes from Vantage" don't match camera interpolations in Chaos Vantage
Chaos Vantage , v1.4.0
Official Release
Date - June 17th, 2021
New Features
Textures
  • Support for the V-Ray MultiSubTex
  • Support for MultiTexture(CGSource)
  • Support for ForestColor
UX
  • Transforms manipulation window
  • Transform snapping
Modified
Textures
  • Extended support for V-Ray Triplanar texture - Random texture offset, Random texture rotation, Random frame rotation, Random axis, Random mode
  • Extended support for V-Ray UVWRandomizer texture - Randomize by name, face ID, render ID, element, instance ID, object ID, particle ID, node handle
Fixes
Camera
  • Difference in FOV and Focal length values between Max and Vantage
  • Film gate and Focal length not importing correctly with multiple cameras
  • Merged cameras get their focal length set from scene Home camera
UX
  • Drag-n-drop gizmo isn't placed correctly with dedpi > 100%
  • Inconsistency in Transparency overlay between NVIDIA AI and Combined/Vantage denoisers
  • Focus distance shortcut functions like Pick focus tool - now behaves as a virtual focus distance slider by moving the mouse left and right.
Denoiser
  • Super bright pixels become black with NVIDIA AI denoiser
vrscene
  • Wrong position of objects with merged vrscenes with different meters_scale
  • Light gizmos scale depending on .vrscene's scale
Chaos Vantage , v1.3.0
Official Release
Date - May 20th, 2021
New Features
Materials
  • Support for the V-Ray 2 Sided Material
Denoiser
  • Implemented NVIDIA AI denoiser
Objects
  • Support for object camera/reflection/refraction/overall visibility and cast/receive shadows properties
Camera
  • Support for animated camera parameters from .vrscene - Focus distance, FOV, Focal length, Zoom factor, ISO, F-number, Shutter speed, Vertical/Horizontal Tilt/Shift
Modified
UX
  • Implemented customizable shortcuts
  • Moved Mouse and Keyboard Shortcuts menu under Edit menu
  • Moved Navigation preset in Mouse and Keyboard Shortcuts menu
  • Statistics for required additional memory in High Quality Snapshot and High Quality Sequence windows
  • Input validation of input fields in UI with Enter, Tab or Space keys
Fixes
  • Incorrect update of materials when enabling/disabling certain features
Lights
  • Mesh lights imported as point lights with incorrect intensity - they are now ignored instead
Output
  • Wrong alpha channel when Light Cache is enabled
Chaos Vantage , v1.2.1
Official Release
Date - April 27, 2021
New Features
Materials
  • Support for the "Reflect on back side" option in the V-Ray Material
  • Support for the "Double-sided" option in the V-Ray Material
Modified
UX
  • Enabled focus picker while in Live Link
Fixes
Materials
  • Refract IOR affects reflections when Fresnel IOR is unlocked
  • Glossy fresnel is not correct when using texture for Fresnel IOR
Chaos Cosmos Browser
  • Wrong scaling of Chaos Cosmos assets when imported to a scene with non-centimeter scale
Chaos Vantage , v1.2.0
Official Release
Date - April 14, 2021
New Features
Materials
  • Support for Clear coat in V-Ray Material
  • Support for glossy Fresnel reflections
Camera
  • Support for importing multiple cameras from one .vrscene file
Environment
  • Background override option to affect refraction and mirror reflection rays
Output
  • Support for saving .PNG files with alpha channel
Modified
UX
  • Animation FPS in Vantage is set based on .vrscene
  • Asset filtering options in the merge scene dialogue on import
  • Disabled tools in the UI that can't be used during Live Link
  • Added specific gizmo shapes for lights depending on their type
.vrscene
  • Improved performance when loading animated .vrscene
Fixes
Live Link
  • Layer and object visibility changes breaking multi-materials in Live Link
Lights
  • Broken disc and rectangle light when loading a new scene after disabling lights
Animation
  • Precision issues with animation of rotating objects
Chaos Vantage , v1.1.1
Official Release
Date - March 04, 2021
Fixes
.vrscene
  • Drop-Merge .vrscene doesn't place it to origin
  • Freeze with .vrscenes containing multiple Nodes with same full name
Navigation
  • Camera orbiting and transitions are incorrect for scenes from V-Ray for Cinema 4D
Sun
  • Fixed Sky is not set correctly for scenes with Y up vector
UX
  • Strange artifacts in viewport when using 'Flip Up Axis Y'
  • Camera tab widens when opening 'Advanced Resolution Settings'
Chaos Vantage , v1.1.0
Official Release
New Features
Chaos Cosmos
Sun
Improvements
.vrscene
  • Improved support for .vrscenes coming from Cinema 4D
Materials
  • Support for MtlMulti IDs larger than 31
UX
Fixes
Live Link
  • Very rare case where Live Link may start with missing objects
High Quality Render
  • Motion blur not working on multiple GPUs
  • First frame of a HQ sequence having big motion blur
Textures
  •  Scenes from V-Ray for Sketchup 5.1 failing to render any textures
UX
  • Viewport selection not working at specific resolutions
  • Transform tools not respecting the single/group select mode
  • Geometry disappearing after scaling it down to zero scale
  • Advanced camera parameter popup not hiding when Camera tab is hidden
  • Overlapping advanced camera parameter popups
Chaos Vantage , v1.0.2
Official Release
Date - February 02, 2021
New Features
UI
Fixes
Live Link
  •  Refractive materials render completely black with live link in Maya
  • Update logic issues
High Quality Render
  • Performance regression when high quality rendering is paused and resumed
Driver
  •  ColorCorrection texture and UVWGenChannel issues caused by 46x.xx series drivers
Chaos Vantage , v1.0.1
Official Release
Date - January 19, 2021
New Features
UI
Modified
UI
  • Tweaks of camera's Advanced parameters windows pop up behaviour
  • Disabled video "Output file type" when rendering sequence with non-perspective camera
Fixes
Live Link
  • Textures coming from V-Ray for Maya not working correctly
CPU
  • Crash when working with CPU with very high thread count
Multi GPU
  • Performance regression with noise threshold
Chaos Vantage , v1.0.0
Official Release
Date - December 02, 2020
New Features
Environment Fog
  • Added two environment fog layers with individual settings
UX
  • Support for deleting objects in the scene
  • Added "Place" functionality when drag and dropping .vrscene
Live Link
  • Added option for installation of 3Ds Max live link scripts in installer
UI
  • Added toggle opacity button in top toolbar
  • Added option to make Chaos Vantage window always on top
Video
  • Record the viewport to an .mp4 file in real time
  • Added .mp4 and .mkv export type for animation
Offline Render
  • Added denoising and motion blur option in render high quality snapshot or sequence
Post
  •   Added color space setting for LUT files
Texture
  • Added support for UVWGenRandomizer
Motion blur
  •  Support for motion blur in offline rendering
MAX Scripts
Modified
Material
  • Improved bump support with scenes generated from V-Ray 5
  • Improved bump parity between Chaos Vantage and V-Ray
Live Link
  • Improved Live link support  with all V-Ray 5 plugins supporting DR
UI
  • Reworked Camera tab parameters layout
  • Improved icon and camera thumbnail rendering for hi dpi monitors
  • Increased environment "Intensity" cap to 1000
  • Replaced EDITOR, LUT and BLOOM buttons with icons
  • Added Feedback Program tab in Preferences menu
  • Improved Shortcuts menu layout
Fixes
Material
  • Bump does not render behind refractive objects
Camera
  • Crash when deleting camera while in "Recording camera movement" mode
  • "Level Camera" does not reset correctly camera roll with an Y scene_upDir
Multi GPU
  • Creeping artifacts with 2 GPUs
Project Lavina is now Chaos Vantage.
Project Lavina Beta, v0.6.0
Beta Release
Date - November 04, 2020
New Features
Live Link
  • Experimental 3ds Max to Lavina live link
Texture
  • Support for Triplanar texture
UI
  • Light gizmos for easy selection of non-area lights when a transform tool is selected
Config .vrdx
  • Loading saved Lavina files(.vrdx) now loads associated .vrscenes
Modified
GPU
  • Improved out-of-memory protection for GPU resources
UI
  • Improved indicator for render state - RENDERING, PAUSED, CAM REC., LIVE LINK
Fixes
Camera
  • Issue when saving camera slot shortcut
  • 'Fill' option squashing image when using a portrait aspect ratio
Lights
  •  Non top level lights in a hierarchy can not be disabled
UI
  •  App window not returning to proper size after a spherical or cube offline render
Texture
  •  Opacity map not working when the texture's alpha channel is used
Project Lavina Beta, v0.5.1
Beta Release
Date - October 08, 2020
New Features
Camera
  • Added Rotation Focus method to Stereo Spherical and Stereo Cube 6x1 camera types
  • Add support for import of Exposure value in Physical Camera
Modified
.vrscenes
  • Improved handling of back face materials from V-Ray 5 for SketchUp .vrscenes
Fixes
UI
  •  Cloning selected objects also duplicate scene lights in Lights tab
CPU
  •  D3D error on machine with large cpu thread count
Project Lavina Beta, v0.5.0
Beta Release
Date - September 03, 2020
New Features
Camera
  • Added Cube 6x1, Spherical and Spherical Stereoscopic camera types to render images and sequences
Modified
  • Improved performance with GPUs set with NVlink connection
Fixes
Animation Editor
  •  Camera thumbnails in timelines are squashed with different aspect ratio
Camera
  • Camera jolts when navigating from a stored camera with a roll
  • Frame selected/scene shortcut doesn't work
  • Home camera not loading correct FOV
Texture
  •  Forest color texture importing black.
Project Lavina Beta, v0.4.4
Beta Release
Date - August 19, 2020
New Features
Camera
  • Tilt and shift corrections for Physical Camera
Modified Features
UX
  •  Color picker dialogue can be moved around
Fixes
.vrscene
  • Incorrect scaling when merging .vrscenes exported with different meter scale
Camera
  • Switching between stored cameras with different FOV results in a jump
Project Lavina Beta, v0.4.3
Beta Release
Date - August 03, 2020
New Features
Lights
  • Support for texture in V-Ray Plane/Rectangle light
  • Support for V-Ray Disk/Ellipse light
License Server
  • License server as part of the installation
GPU
  • GPU driver check for currently unsupported and recommended drivers
Modified Features
Camera
  •  Improved Camera roll navigation action
UX
  •  "Check for updates" button in Help menu
  • Build date and time info in About dialog
Fixes
Animation Editor
  •  Transient clip in animation editor cannot be selected or modified
  • Pivot point not moving with object when animated from imported .vrscene
Denoiser
  • Artifacts around very bright light source
  • Reflection artifacts when using two GPUs
Project Lavina Beta, v0.4.2
Beta Release
Date - July 22, 2020
Fixes
Video Driver
  • Startup error (D3D error) with 450 series NVidia drivers
Project Lavina Beta, v0.4.1
Beta Release
Date - July 10, 2020
Fixes
Camera
  •  Physical camera parameters not syncing when switching camera slots
  • Physical camera parameters scaling erroneously when loading from vrdx file
Animation Editor
  • Physical cameras not interpolating correctly in animation editor when using FoV
  • 'Aperture size' interpolation in animation editor
Denoiser
  • Denoiser issue when using more than one GPU
Project Lavina Beta, v0.4.0
New Features
Camera
  • Camera roll functionality
Material
  • Support for metalness (BRDFVrayMtl)
UI
  • Pivot point selection button to top toolbar
  • Mouse precision toggle button
MAXScript
Modified Features
Denoiser
  • Improved denoiser:
    • Details from small objects and shadows are less blurry
    • Reduced halo/bloom effect around objects
Animation Editor
  • Improved UX :
    • Increase the pickup radius for selecting thin areas - timeline marker, clip edges.
    • Make the rightmost 20px of a clip with two drag-able controls.
    • Transient clips are not resizable when dragged, only their position change.
    • Transient clips have a better thicker line indicator
    • Increase the limit of the "Def. duration" spinner to 1000 (approx. 10 sec @ 90fps )
Project Lavina Beta, v0.3.1
Beta Release
Date - July 01, 2020
Fixes
  • Imported animated sun from .vrscene not being animated in Lavina
Project Lavina Beta, v0.3.0
Beta Release
Date - June 26, 2020
New Features
  • Added Animation Editor (experimental)
  • Added Light grouping(instancing) on imported lights
  • Added support for V-Ray Sun and Sky models
  • Added Noise threshold option
  • Added Support for Simple(environment) light portal
  • Added support for CommonTexture and MappedTexture set of texture parameters: Crop, Place, AlphaSource, MonoChannelOutput, RGBChannelOutput, Invert, OutputAmount, Clamp, RGBOffset, RGBLevel
Modified Features
  • Improved Color Picker - interactive updates, color temperature, color presets, color range options
  • Improved UI:
    • Last snapshot render time information
    • Selecting a light focuses it in the light lister
  • Improved visual parity between Lavina and V-Ray
Project Lavina Beta, v0.2.3
Beta Release
Date - May 07, 2020
New Features
  • Added new Camera list with thumbnails and set, delete and reorder functionality
  • Added support for Directional, Omni and Spot lights from 3Ds Max
  • Added support for Instanced objects from Maya/Modo/Houdini
  • Added "Display to render ratio" control in the toolbar
Modified Features
  • Improved navigation - Selection Pivot Type
  • Improved denoiser - Artifacts with motion blur with fast moving objects are reduced
  • Improved denoiser - textures behind refractive objects are less blurry
  • Improved UI - RMB to reset value to default
Project Lavina Beta, v0.2.2
Beta Release
Date - April 09, 2020
New Features
  • Support for IES lights
  • Support for Spot lights from Maya/Modo/Katana/Cinema4D/Sketchup/Rhino
  • Object pivot import and manipulation
  • Move Pivot tool
  • Navigation target type option - Ray hit or Camera target
Modified Features
  • Improved navigation - gizmo for orbit pivot and zoom point
Bug Fixes
  • Fixed bug with rotation and scaling in local space
Project Lavina Beta, v0.2.1
Beta Release
Date - March 26, 2020
Modified Features
  • Improved denoiser blending - added simple adaptivity to raw/denoised blending to filter out extreme noise
  • Improved camera navigation
  • Improved camera transitions with quadratic interpolation function instead of linear
  • Improvement: Environment image is now cleared when loading a new scene
  • Improvement: Removed automatic cycle back to first camera when in "Camera" animation mode
  • Improved UI - removed Modifier key option and include them in navigation preset
  • Improved UI - Shortcuts update according to navigation preset
Project Lavina Beta, v0.2.0
Beta Release
Date - March 12, 2020
New Features
  • Support for opacity maps in "clip" mode. Only bitmaps are supported
  • Separate background option for camera rays instead of the "environment" color/image
  • Importing of Dome light texture as Environment
  • Navigation presets: Max, Maya, Sketchup
  • "Run" when in Free-Look mode
Modified Features
  • Improved rendering of refractive objects on reflective surfaces
  • Improved light cache - it is cleared when a render setting is changed
  • Improved animation experience: Scene, Walkthrough and Cameras mode
  • Improved scene navigation experience
  • Improved status bar
Bug Fixes
  • Fixed denoiser silhouette artifacts
  • Fixed collision enabled only in Free-Look mode
  • Fixed undo action for some local space rotations
