Square Enix © Goodbye Kansas
« Previous Version 12 Next »
The Total Lighting Render Element stores all direct and indirect lighting in the scene.
The Total Lighting Render Element is a color image that includes the effects of both direct and indirect lighting on materials in the scene, including the diffuse component. It is a result of adding the vrayRE_Lighting and vrayRE_GI render elements, or of multiplying the vrayRE_Raw_Total_Light and vrayRE_Diffuse Render Elements.
Specific objects can be excluded from this Render Element by disabling the Generate Render Elements option in the VRayObjectProperties node for the selected object(s).
MultiExcerpt named RE was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Attributes
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.totalLight.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Common uses
The Total Lighting Render Element is useful for brightening or dimming all lighting during compositing. Below are a couple of examples of its use.
Original Beauty Composite
Brightened Total Lighting Render Element
Brightened and tinted Total Lighting Render Element
Brightened Lights
Tinted Lights
Compositing Formulas
vrayRE_Raw_Total_Light x vrayRE_Diffuse = vrayRE_Total_Light
vrayRE_Lighting + vrayRE_GI = vrayRE_Total_Light
