This page provides information on V-Ray Render Settings integrated in Solaris Render Settings LOP node.
V-Ray Render Settings are located in the V-Ray tab of the Render Settings LOP. The settings are similar to those of the V-Ray Renderer ROP and become accessible when you create a Render Settings LOP from ||stage|| > Rendering > Render Settings. By default, none of the parameters are set in the USD unless specified by Creating and Setting Attributes.
Some of the settings are also available in Houdini's Display Options toolbar.
The parameters that correspond to a USD attribute have a pop-up menu that controls how the LOP node authors the attribute.
The Viewport Settings can be accessed in the Display Options toolbar, or from the Display Options: Solaris window (press D or click the button).
The Show Denoised Result toggle denoises the render in the viewport. Note that a V-Ray Denoiser render element must be present and enabled for this toggle to work.
The Headlight Creation toggle creates headlight if no lights are present in the scene.
Solaris workflows consist of connecting numerous Solaris nodes together. The rendering process requires a Render Settings LOP and a USD Render ROP. Additional nodes such as V-Ray Render Vars LOP can be used to create AOVs.
