« Previous Version 43 Next »
Chaos Vantage , v1.7.3
Official Release
Date - June 08, 2022
Modified
  • Added support for V-Ray 6 (beta) builds.
Exposure
  • Auto-exposure smoothing over time in High Quality sequence rendering. It is determined from FPS and Auto exposure time. Set Auto exposure time to 0 for previous behavior.
UI
  • Improved message log UI:
    • Added button in the status bar for easier access.
    • Search filter now filters and shows only lines that have the input string.
    • Added Filter menu to specify the type of message to show in the log window.
    • Added Wrap lines button.
    • Added Clear log widow button.
    • Added Open log location button.
Fixes
Performance
  • CPU memory leak when uploading textures.
  • Potential delay in version check during startup
Live Link
  • Files not saving with Non-ascii filename characters when using 'Render animation with Chaos Vantage"
Chaos Vantage , v1.7.2
Official Release
Date - May 19, 2022
New feature
Exposure
Texture
  • Support for negative values for textures.
Fixes
Installer
  •  Embedded Chaos Cosmos installer downgrades newer installed version
Lights
  •  Crash when deleting grouped lights
Live Link
  •  Camera type is not consistent throughout the entire animation sequence when using 'Render animation with Chaos Vantage, using Vantage UI'
Chaos Vantage , v1.7.1
Official Release
Date - April 13, 2022
New feature
Texture
  • Partial support for V-Ray Edges texture - rounded corners are not implemented
Modified
.vantage
  • Geolocated sun animation is saved in the .vantage file
Navigation
  •  Support for mapping Chaos Vantage shortcuts through the SpaceMouse/3DConnexion controller
UX
  • 'Render setup' dialog retains settings when closed and between sessions. 'Save defaults' checkbox is removed from UI
  • Light gizmos now have consistent line width and size at different render resolution and viewport size
UI
  • Upper limit for the number of light tree samples is increased to 16
Fixes
Environment
  •  Wrong overriding of the current environment texture when using "Open Scene as Config Only..."
Chaos Vantage , v1.7.0
Official Release
Date - March 30, 2022
New Features
Textures
  • Support for normal maps
Clay mode
Ambient  occlusion
Sun animation
Menu
Navigation
  • Support for 3DConnexion SpaceMouse controller
Supported output formats
  • Implemented .jpg/.jpeg file type output
Modified
Ambient light
UX
Fixes
.vantage file
  • The .vrscene environment texture is not used when loading a .vrscene with an associated .vantage file
Memory
  • Memory leak when HQ rendering with denoiser
  • Changing a VRayLight from Plane to Dome not updating correctly
Camera
  • Crash when renaming a camera
Geometry
  • Crash when deleting objects
Chaos Vantage , v1.6.2
Official Release
Date - January 11, 2022
New feature
Texture
  • Support for the "auto" color space transfer function of VRayBitmap
Modified
.vantage
  • When the root .vrscene is not found with its absolute path it's searched for in the folder containing the .vantage file
Fixes
Multi GPU
  •  Line artifacts in interactive mode when using multiple GPUs
UI
  • Duplicate objects showing up in object list (with scenes from Maya)
Memory
  • Crash when out of GPU memory and the scene has a rectangle light with a texture
Tools
  • Issues in "Import changes from Vantage" MAX script:
    • Importing cameras from a .vantage file does not set the frame rate
    • Unexpected values for the "Exposure value" keys
Live Link
  • Live link failing to start when "Save strings in legacy non-scene files using UTF8" is enabled in 3ds Max
.vantage
  • Error when using "Save scene settings as default"
UX
  • Undo action not working properly after a select-all(CTRL+A) action in the objects list
Chaos Vantage , v1.6.1
Official Release
Date - December 16, 2021
Modified
UX
  • Place tool now locks the selected object's current orientation while SHIFT key is pressed
  • A sample HDR file is loaded when opening non-vrscene files
UI
  • Added progress indication when importing FBX, OBJ, 3DS, PLY, STL, TER, DAE, GLTF file formats
Textures
  • Better parity when using the VRayUVWRandomizer in V-Ray for Cinema4D
Non-vrscene files
  • Default up direction (now Y) for OBJ and 3DS files
Fixes
Live Link
  • Animation rendering started with Vantage UI renders the same frame over and over
  • Animation synchronization bug in 3ds Max
.vantage file
  • Deleting an instance of an appended scene resulting in an incorrectly saved .vantage file
Memory
  • Excessive shared GPU memory usage with certain large .OBJ scenes
Environment
  • HDR rotation not importing with vrscene generated from Revit
Non-vrscene files
  • TerraGen (.ter) files doesn't import
UX
  • Camera view getting reset to the original camera after placing an asse
  • Pressing ESC while using Place tool makes selected object to be unselectable
  • Issues when switching between Still and Sequence in the Render setup dialog
Chaos Vantage , v1.6.0
Official Release
Date - December 06, 2021
New Features
Cosmos materials
Batch rendering
UX
  • Import option in the File menu for easier importing of supported file formats
Supported formats
  • Experimental support for opening and importing FBX, OBJ, 3DS, PLY, STL, TER, DAE, GLTF file formats
Modified
UX
Performance
  • Optimized GPU memory usage:
    • Light Cache is now several times smaller
    • Unused textures are unloaded from the GPU
Live Link
  • Creation and updating of textures for lights
Fixes
Textures
  • VRayMultiTexture and VRayTriplanar randomization options not working with scenes from V-Ray 5, update 2
Memory
  • Crash after loading a new scene after a failed memory allocation
Multi GPU
  • Line artifacts with multi GPU after opening the material browser
Chaos Vantage , v1.5.3
Official Release
Date - November 11, 2021
New Features
Material tab
  • Material name searching, type filtering and sorting(name and creation)
  • Select the material of the selected object button
UX
  • Drag-and-drop material assignment with preview
  • Alt+drag-and-drop replaces material on all object with same material
  • Ctrl+drag-and-drop assigns material to objects and its children
Import
  • Support for ply, obj, bin, geo, hclassic, bgeo, bhclassic, prt, and partial (no animation, hair and particles) support for alembic files
Modified
UX
  • Cosmos browser doesn't show importer choice inside Chaos Vantage when multiple importers are running
  • Motion blur is not allowed for non-perspective (Cube 6x1, Spherical and stereo) cameras.
Performance
  • Optimized memory usage of texture files with a single color
  • Optimized memory usage for material previews
Live Link
  • Implemented HDRI environment and dome light creation and updating
Fixes
Live Link
  • Several parameters not working in the Render Animation via Live Link dialog in 3ds Max
Console
  • Incorrect frame rate when rendering through console
.vantage file
  • Animation editor settings not getting saved to .vantage file
Material tab
  • Wrong material thumbnails after loading a new scene
Chaos Vantage , v1.5.2
Official Release
Date - October 21, 2021
Fixes
Snapshot
  • "Render High Quality Snapshot"not showing progress bar
Camera
  • Crash with overwritten vrscene camera when used in animation
Chaos Vantage , v1.5.1
Official Release
Date - October 20, 2021
Fixes
Animation editor
  • Render sequence renders only current fame
  • Pause element not exported properly
  • Scene camera in camera animation track cancelling other object animations
Live Link
  • Incorrect transformation of objects, lights and cameras from Cinema 4D
Chaos Vantage , v1.5.0
Official Release
Date - October 19th, 2021
Please note that  .vantage files saved with version 1.5.0 and newer are not compatible with older versions.
New Features
Place tool
Camera
  • Support for per camera resolution
Command Line
Environment
  • Flip horizontally option for the environment texture.
Material tab UI
Output
  • Top/Bottom option for Stereo Cube 6x1 and Stereo spherical outputs
  • FOV X and FOV  Y have now decimal values instead of single integer
Modified
Live Link
  • Render animation in Live Link session from 3ds Max (requires  V-Ray for 3ds Max upcoming update)
Lights
  • Save all lights parameters in .vantage file
UI
  • Replaced denoiser slider in toolbar with an On/Off button when using the NVidia AI denoiser or Combined denoiser
Camera
  • Enable imported cameras to be drag-able to Camera animation track
Animation editor
Installer
  • Removed Install V-Ray for 3ds Max Live link scripts option and from ||Customize|| > Customize User Interface > Toolbars > Chaos Vantage in 3ds Max
  • Added option to associate . Vantage files so that they can be opened with Chaos Vantage from the explorer
Fixes
UI
  • Wrong display of object hierarchy
  • UI font bug when in non-latin OS
  • Closing Cosmos Browser from 'X' doesn't update UI
Camera
  • Automatic vertical tilt doesn't work correctly with scenes with Y-up axis
Lights
  • Environment map is flipped from Cinema 4D
  • Environment map not importing when "TexRGBTintMax"is used to color correct it
Multi GPU
  • Black spots in denoised offline render on multi-GPU
  vrscene file
  • Incorrect transforms import of meshes in a hierarchy from Cinema 4D when using Cloner in Multi Instance mode
  • Incorrect node visibility animation when some frames don't have a keyframe from Cinema 4D
Crash
  • Crash on app launch with external GPUs
Chaos Vantage , v1.4.2
Official Release
Date - July 21st, 2021
New Features
Camera
Output
  • Support for saving EXR (16-bit) images - the main image is linear, without color corrections and post-effects. Available channels: Bumped Normals, Depth, Screen Velocity, Albedo, Additional (Background & Lights)
Materials
  • Basic support for the V-Ray Car Paint 2 Material
Modified
Materials
  • Improve support for the V-Ray Car Paint Material
Fixes
Output
  • Light gizmos are rendered in final sequence
  • Chaos Vantage renders different frame number compared to Max
  • Chaos Vantage renders 1 frame less than the full timeline
Animation editor
  • Animation timeline cannot display more than 1 transient clips on the right
  • Cannot select transient clip on the right of the timeline
Vantage file
  • Can't save vantage file when path contains non-Latin characters
Crash
Chaos Vantage , v1.4.1
Official Release
Date - July 2nd, 2021
New Features
Textures
  • Support for Substance textures
  • Support for SketchUp native textures and colorization
UX
Geometry
  • Support for animated object visibility from a .vrscene file
Modified
UX
  • Improved snapping and transforms windows:
    • Added 'S' as shortcut to toggle snap on/off
    • Don't hide the dialogue when exiting free look mode and the window has been opened beforehand
    • Spinboxes display scene units
  • Improved Offline render UI:
    • Added resolution preset
    • Added aspect ratio control
Geometry
  • Support for Edge boundary checking in Forest Pack
Tools
  • Support for importing camera parameters(static and animated) with 'Import changes from Vantage' tool in 3ds Max
  • Imported cameras are now named [VANTAGE FILE NAME]_[CAMERA NAME]_###
Fixes
Camera
  • Auto vertical tilt doesn't keep vertical lines in camera transitions
  • Camera rolls while transitioning between two upright positions
UX
  • Collision detection regression
  • "Orbit" and "Look around" navigation are uncontrollable when on second monitor and >150% dpi scale
  • Scene up vector is not applied correctly to merged .vrscenes/cosmos assets
Materials
  • 2-Sided material doesn't work correctly in SketchUp/Rhino/Revit/Cinema4D
Textures
  • Crash with TexMulti when it has an unsupported sub-texture connected to it
  • Vantage doesn't match V-Ray when TexMulti has an empty textures list and random hue/sat/gamma
Tools
  • "Overwrite existing" in "Import changes from Vantage" doesn't work for Chaos Vantage animated camera
  • Camera Interpolations imported with "Import changes from Vantage" don't match camera interpolations in Chaos Vantage
Chaos Vantage , v1.4.0
Official Release
Date - June 17th, 2021
New Features
Textures
  • Support for the V-Ray MultiSubTex
  • Support for MultiTexture(CGSource)
  • Support for ForestColor
UX
  • Transforms manipulation window
  • Transform snapping
Modified
Textures
  • Extended support for V-Ray Triplanar texture - Random texture offset, Random texture rotation, Random frame rotation, Random axis, Random mode
  • Extended support for V-Ray UVWRandomizer texture - Randomize by name, face ID, render ID, element, instance ID, object ID, particle ID, node handle
Fixes
Camera
  • Difference in FOV and Focal length values between Max and Vantage
  • Film gate and Focal length not importing correctly with multiple cameras
  • Merged cameras get their focal length set from scene Home camera
UX
  • Drag-n-drop gizmo isn't placed correctly with dedpi > 100%
  • Inconsistency in Transparency overlay between NVIDIA AI and Combined/Vantage denoisers
  • Focus distance shortcut functions like Pick focus tool - now behaves as a virtual focus distance slider by moving the mouse left and right.
Denoiser
  • Super bright pixels become black with NVIDIA AI denoiser
vrscene
  • Wrong position of objects with merged vrscenes with different meters_scale
  • Light gizmos scale depending on .vrscene's scale
Chaos Vantage , v1.3.0
Official Release
Date - May 20th, 2021
New Features
Materials
  • Support for the V-Ray 2 Sided Material
Denoiser
  • Implemented NVIDIA AI denoiser
Objects
  • Support for object camera/reflection/refraction/overall visibility and cast/receive shadows properties
Camera
  • Support for animated camera parameters from .vrscene - Focus distance, FOV, Focal length, Zoom factor, ISO, F-number, Shutter speed, Vertical/Horizontal Tilt/Shift
Modified
UX
  • Implemented customizable shortcuts
  • Moved Mouse and Keyboard Shortcuts menu under Edit menu
  • Moved Navigation preset in Mouse and Keyboard Shortcuts menu
  • Statistics for required additional memory in High Quality Snapshot and High Quality Sequence windows
  • Input validation of input fields in UI with Enter, Tab or Space keys
Fixes
Live Link
  • Incorrect update of materials when enabling/disabling certain features
Lights
  • Mesh lights imported as point lights with incorrect intensity - they are now ignored instead
Output
  • Wrong alpha channel when Light Cache is enabled
Chaos Vantage , v1.2.1
Official Release
Date - April 27, 2021
New Features
Materials
  • Support for the "Reflect on back side" option in the V-Ray Material
  • Support for the "Double-sided" option in the V-Ray Material
Modified
UX
  • Enabled focus picker while in Live Link
Fixes
Materials
  • Refract IOR affects reflections when Fresnel IOR is unlocked
  • Glossy fresnel is not correct when using texture for Fresnel IOR
Chaos Cosmos Browser
  • Wrong scaling of Chaos Cosmos assets when imported to a scene with non-centimeter scale
Chaos Vantage , v1.2.0
Official Release
Date - April 14, 2021
New Features
Materials
  • Support for Clear coat in V-Ray Material
  • Support for glossy Fresnel reflections
Camera
  • Support for importing multiple cameras from one .vrscene file
Environment
  • Background override option to affect refraction and mirror reflection rays
Output
  • Support for saving .PNG files with alpha channel
Modified
UX
  • Animation FPS in Vantage is set based on .vrscene
  • Asset filtering options in the merge scene dialogue on import
  • Disabled tools in the UI that can't be used during Live Link
  • Added specific gizmo shapes for lights depending on their type
.vrscene
  • Improved performance when loading animated .vrscene
Fixes
Live Link
  • Layer and object visibility changes breaking multi-materials in Live Link
Lights
  • Broken disc and rectangle light when loading a new scene after disabling lights
Animation
  • Precision issues with animation of rotating objects
Chaos Vantage , v1.1.1
Official Release
Date - March 04, 2021
Fixes
.vrscene
  • Drop-Merge .vrscene doesn't place it to origin
  • Freeze with .vrscenes containing multiple Nodes with same full name
Navigation
  • Camera orbiting and transitions are incorrect for scenes from V-Ray for Cinema 4D
Sun
  • Fixed Sky is not set correctly for scenes with Y up vector
UX
  • Strange artifacts in viewport when using 'Flip Up Axis Y'
  • Camera tab widens when opening 'Advanced Resolution Settings'
Chaos Vantage , v1.1.0
Official Release
New Features
Chaos Cosmos
Sun
Improvements
.vrscene
  • Improved support for .vrscenes coming from Cinema 4D
Materials
  • Support for MtlMulti IDs larger than 31
UX
Fixes
Live Link
  • Very rare case where Live Link may start with missing objects
High Quality Render
  • Motion blur not working on multiple GPUs
  • First frame of a HQ sequence having big motion blur
Textures
  •  Scenes from V-Ray for Sketchup 5.1 failing to render any textures
UX
  • Viewport selection not working at specific resolutions
  • Transform tools not respecting the single/group select mode
  • Geometry disappearing after scaling it down to zero scale
  • Advanced camera parameter popup not hiding when Camera tab is hidden
  • Overlapping advanced camera parameter popups
Chaos Vantage , v1.0.2
Official Release
Date - February 02, 2021
New Features
UI
Fixes
Live Link
  •  Refractive materials render completely black with live link in Maya
  • Update logic issues
High Quality Render
  • Performance regression when high quality rendering is paused and resumed
Driver
  •  ColorCorrection texture and UVWGenChannel issues caused by 46x.xx series drivers
Chaos Vantage , v1.0.1
Official Release
Date - January 19, 2021
New Features
UI
Modified
UI
  • Tweaks of camera's Advanced parameters windows pop up behaviour
  • Disabled video "Output file type" when rendering sequence with non-perspective camera
Fixes
Live Link
  • Textures coming from V-Ray for Maya not working correctly
CPU
  • Crash when working with CPU with very high thread count
Multi GPU
  • Performance regression with noise threshold
Chaos Vantage , v1.0.0
Official Release
Date - December 02, 2020
New Features
Environment Fog
  • Added two environment fog layers with individual settings
UX
  • Support for deleting objects in the scene
  • Added "Place" functionality when drag and dropping .vrscene
Live Link
  • Added option for installation of 3Ds Max live link scripts in installer
UI
  • Added toggle opacity button in top toolbar
  • Added option to make Chaos Vantage window always on top
Video
  • Record the viewport to an .mp4 file in real time
  • Added .mp4 and .mkv export type for animation
Offline Render
  • Added denoising and motion blur option in render high quality snapshot or sequence
Post
  •   Added color space setting for LUT files
Texture
  • Added support for UVWGenRandomizer
Motion blur
  •  Support for motion blur in offline rendering
MAX Scripts
Modified
Material
  • Improved bump support with scenes generated from V-Ray 5
  • Improved bump parity between Chaos Vantage and V-Ray
Live Link
  • Improved Live link support  with all V-Ray 5 plugins supporting DR
UI
  • Reworked Camera tab parameters layout
  • Improved icon and camera thumbnail rendering for hi dpi monitors
  • Increased environment "Intensity" cap to 1000
  • Replaced EDITOR, LUT and BLOOM buttons with icons
  • Added Feedback Program tab in Preferences menu
  • Improved Shortcuts menu layout
Fixes
Material
  • Bump does not render behind refractive objects
Camera
  • Crash when deleting camera while in "Recording camera movement" mode
  • "Level Camera" does not reset correctly camera roll with an Y scene_upDir
Multi GPU
  • Creeping artifacts with 2 GPUs
Project Lavina is now Chaos Vantage.
Project Lavina Beta, v0.6.0
Beta Release
Date - November 04, 2020
New Features
Live Link
  • Experimental 3ds Max to Lavina live link
Texture
  • Support for Triplanar texture
UI
  • Light gizmos for easy selection of non-area lights when a transform tool is selected
Config .vrdx
  • Loading saved Lavina files(.vrdx) now loads associated .vrscenes
Modified
GPU
  • Improved out-of-memory protection for GPU resources
UI
  • Improved indicator for render state - RENDERING, PAUSED, CAM REC., LIVE LINK
Fixes
Camera
  • Issue when saving camera slot shortcut
  • 'Fill' option squashing image when using a portrait aspect ratio
Lights
  •  Non top level lights in a hierarchy can not be disabled
UI
  •  App window not returning to proper size after a spherical or cube offline render
Texture
  •  Opacity map not working when the texture's alpha channel is used
Project Lavina Beta, v0.5.1
Beta Release
Date - October 08, 2020
New Features
Camera
  • Added Rotation Focus method to Stereo Spherical and Stereo Cube 6x1 camera types
  • Add support for import of Exposure value in Physical Camera
Modified
.vrscenes
  • Improved handling of back face materials from V-Ray 5 for SketchUp .vrscenes
Fixes
UI
  •  Cloning selected objects also duplicate scene lights in Lights tab
CPU
  •  D3D error on machine with large cpu thread count
Project Lavina Beta, v0.5.0
Beta Release
Date - September 03, 2020
New Features
Camera
  • Added Cube 6x1, Spherical and Spherical Stereoscopic camera types to render images and sequences
Modified
  • Improved performance with GPUs set with NVlink connection
Fixes
Animation Editor
  •  Camera thumbnails in timelines are squashed with different aspect ratio
Camera
  • Camera jolts when navigating from a stored camera with a roll
  • Frame selected/scene shortcut doesn't work
  • Home camera not loading correct FOV
Texture
  •  Forest color texture importing black.
Project Lavina Beta, v0.4.4
Beta Release
Date - August 19, 2020
New Features
Camera
  • Tilt and shift corrections for Physical Camera
Modified Features
UX
  •  Color picker dialogue can be moved around
Fixes
.vrscene
  • Incorrect scaling when merging .vrscenes exported with different meter scale
Camera
  • Switching between stored cameras with different FOV results in a jump
Project Lavina Beta, v0.4.3
Beta Release
Date - August 03, 2020
New Features
Lights
  • Support for texture in V-Ray Plane/Rectangle light
  • Support for V-Ray Disk/Ellipse light
License Server
  • License server as part of the installation
GPU
  • GPU driver check for currently unsupported and recommended drivers
Modified Features
Camera
  •  Improved Camera roll navigation action
UX
  •  "Check for updates" button in Help menu
  • Build date and time info in About dialog
Fixes
Animation Editor
  •  Transient clip in animation editor cannot be selected or modified
  • Pivot point not moving with object when animated from imported .vrscene
Denoiser
  • Artifacts around very bright light source
  • Reflection artifacts when using two GPUs
Project Lavina Beta, v0.4.2
Beta Release
Date - July 22, 2020
Fixes
Video Driver
  • Startup error (D3D error) with 450 series NVidia drivers
Project Lavina Beta, v0.4.1
Beta Release
Date - July 10, 2020
Fixes
Camera
  •  Physical camera parameters not syncing when switching camera slots
  • Physical camera parameters scaling erroneously when loading from vrdx file
Animation Editor
  • Physical cameras not interpolating correctly in animation editor when using FoV
  • 'Aperture size' interpolation in animation editor
Denoiser
  • Denoiser issue when using more than one GPU
Project Lavina Beta, v0.4.0
New Features
Camera
  • Camera roll functionality
Material
  • Support for metalness (BRDFVrayMtl)
UI
  • Pivot point selection button to top toolbar
  • Mouse precision toggle button
MAXScript
Modified Features
Denoiser
  • Improved denoiser:
    • Details from small objects and shadows are less blurry
    • Reduced halo/bloom effect around objects
Animation Editor
  • Improved UX :
    • Increase the pickup radius for selecting thin areas - timeline marker, clip edges.
    • Make the rightmost 20px of a clip with two drag-able controls.
    • Transient clips are not resizable when dragged, only their position change.
    • Transient clips have a better thicker line indicator
    • Increase the limit of the "Def. duration" spinner to 1000 (approx. 10 sec @ 90fps )
Project Lavina Beta, v0.3.1
Beta Release
Date - July 01, 2020
Fixes
  • Imported animated sun from .vrscene not being animated in Lavina
Project Lavina Beta, v0.3.0
Beta Release
Date - June 26, 2020
New Features
  • Added Animation Editor (experimental)
  • Added Light grouping(instancing) on imported lights
  • Added support for V-Ray Sun and Sky models
  • Added Noise threshold option
  • Added Support for Simple(environment) light portal
  • Added support for CommonTexture and MappedTexture set of texture parameters: Crop, Place, AlphaSource, MonoChannelOutput, RGBChannelOutput, Invert, OutputAmount, Clamp, RGBOffset, RGBLevel
Modified Features
  • Improved Color Picker - interactive updates, color temperature, color presets, color range options
  • Improved UI:
    • Last snapshot render time information
    • Selecting a light focuses it in the light lister
  • Improved visual parity between Lavina and V-Ray
Project Lavina Beta, v0.2.3
Beta Release
Date - May 07, 2020
New Features
  • Added new Camera list with thumbnails and set, delete and reorder functionality
  • Added support for Directional, Omni and Spot lights from 3Ds Max
  • Added support for Instanced objects from Maya/Modo/Houdini
  • Added "Display to render ratio" control in the toolbar
Modified Features
  • Improved navigation - Selection Pivot Type
  • Improved denoiser - Artifacts with motion blur with fast moving objects are reduced
  • Improved denoiser - textures behind refractive objects are less blurry
  • Improved UI - RMB to reset value to default
Project Lavina Beta, v0.2.2
Beta Release
Date - April 09, 2020
New Features
  • Support for IES lights
  • Support for Spot lights from Maya/Modo/Katana/Cinema4D/Sketchup/Rhino
  • Object pivot import and manipulation
  • Move Pivot tool
  • Navigation target type option - Ray hit or Camera target
Modified Features
  • Improved navigation - gizmo for orbit pivot and zoom point
Bug Fixes
  • Fixed bug with rotation and scaling in local space
Project Lavina Beta, v0.2.1
Beta Release
Date - March 26, 2020
Modified Features
  • Improved denoiser blending - added simple adaptivity to raw/denoised blending to filter out extreme noise
  • Improved camera navigation
  • Improved camera transitions with quadratic interpolation function instead of linear
  • Improvement: Environment image is now cleared when loading a new scene
  • Improvement: Removed automatic cycle back to first camera when in "Camera" animation mode
  • Improved UI - removed Modifier key option and include them in navigation preset
  • Improved UI - Shortcuts update according to navigation preset
Project Lavina Beta, v0.2.0
Beta Release
Date - March 12, 2020
New Features
  • Support for opacity maps in "clip" mode. Only bitmaps are supported
  • Separate background option for camera rays instead of the "environment" color/image
  • Importing of Dome light texture as Environment
  • Navigation presets: Max, Maya, Sketchup
  • "Run" when in Free-Look mode
Modified Features
  • Improved rendering of refractive objects on reflective surfaces
  • Improved light cache - it is cleared when a render setting is changed
  • Improved animation experience: Scene, Walkthrough and Cameras mode
  • Improved scene navigation experience
  • Improved status bar
Bug Fixes
  • Fixed denoiser silhouette artifacts
  • Fixed collision enabled only in Free-Look mode
  • Fixed undo action for some local space rotations
