V-Ray includes a menu with easy shortcuts to some of the most commonly used V-Ray components.
The menu consists of the following submenus: Asset Editor, Chaos Cloud Collaboration, Chaos Cosmos, File Path Editor, Frame Buffer, Light Gen, Rendering, Lights, Objects, Tools, Preferences, Pack Project, and Help.
V-Ray Menu
MenuDescription
Asset EditorOpens the  V-Ray Asset Editor.
Chaos Cloud CollaborationOpens the Chaos Cloud Collaboration window.
Chaos CosmosOpens the Chaos Cosmos Browser.
File Path EditorOpens the  V-Ray File Path Editor.
Frame BufferOpens the V-Ray Frame Buffer.
Light GenOpens the V-Ray Light Gen.
V-Ray RenderingOpens the V-Ray Rendering submenu.
V-Ray LightsOpens the V-Ray Lights submenu.
V-Ray Objects
Opens the V-Ray Objects submenu.
ToolsOpens the V-Ray Tools submenu.
PreferencesOpens the Preferences submenu..
Pack Project1 2Allows you to create a Zip file that contains the project file and all the associated assets used in the file (textures, environment maps, proxies, linked blocks and their assets, etc).
HelpOpens the Help menu.
V-Ray Rendering Submenu
This submenu contains shortcuts to general V-Ray components.
Menu Items
Description
Render
Renders the current view with the V-Ray production renderer.
Interactive Render
Starts a V-Ray Interactive Render.
Render on the CloudSubmits the scene to Chaos Cloud.
V-Ray VisionStarts V-Ray Vision.
Chaos VantageStarts Chaos Vantage.
Export VRScene
Exports a VRScene for render.
Batch Render
Shows a V-Ray Batch Render panel.
V-Ray Lights Submenu
This submenu contains shortcuts for creating V-Ray Lights.
Menu
Description
Rectangle Light
Creates a V-Ray Rectangle Light, also known as Area Light. Specify three points in the viewport to define the rectangle and create the light.
Sphere Light
Creates a V-Ray Sphere Light. Click in the viewport to define the sphere and create the light.
IES Light
Creates a V-Ray IES Light. Click in the viewport to define the cone of light.
Spot Light
Creates a V-Ray Spotlight. Click in the viewport to define the spotlight's cone of light.
Point Light
Creates a V-Ray Point Light, also known as an Omni Light. Click in the viewport to place the point light.
Dome Light
Creates a V-Ray Dome Light. Click in the viewport to place the sphere. Rhino will prompt the user to specify a dome light texture.
Sun Light
Creates a V-Ray Sun. Launches a Sun Angle Calculator, then allows the user to specify the sun position.
Directional Light
Creates a V-Ray Directional Light. Click in the viewport to define the light direction.
Convert to Mesh Light
Converts the selected mesh into a V-Ray Mesh Light object.
Release Mesh Light Properties
Removes V-Ray Mesh Light properties from the selection.
V-Ray Objects Submenu
This submenu contains shortcuts for creating V-Ray Geometry objects.
Menu
Description
Infinite Plane
Creates a V-Ray Infinite Plane.
Export Proxy
Exports a V-Ray Proxy object.
Import Proxy or VRScene
Imports a V-Ray Proxy object or a .vrscene file into the scene.
Add Fur to Selection
Creates a V-Ray Fur Object. Specify an object in the viewport that the fur will be applied to.
Convert to Clipper
Creates a V-Ray Mesh Clipper plane.
Add Displacement to SelectionAdds V-Ray Displacement to selection.
Convert to Scatter Host
Converts selected objects to Scatter hosts.
DecalCreates V-Ray Decal that projects one material on top of another.
Convert to EnmeshCreates a V-Ray Enmesh surface object.
V-Ray Tools Submenu
This submenu contains shortcuts for additional V-Ray Tool functions.
Menu
Description
Camera Focus Tool
Sets camera focus distance based on a point in the model.
Guess Lens Shift
V-Ray will guess the amount of lens shift that has occurred. Note that it is not usable in any default orthogonal view.
Toggle Camera LockLocks camera position and orientation during Interactive Rendering.
Randomize Object IDs
Randomizes the Object IDs for the selected objects.
Convert Rhino Material
Converts Rhino materials to V-Ray materials.
Randomize Material ID Colors 3
Iterates through all V-Ray materials in the project and for each one assigns a randomly generated color to its ID color parameter.
Apply Enscape Settings
Synchronizes Enscape’s environment and illumination - Sunlight, Sky, and Camera exposure settings with V-Ray's.
External
Opens the external submenu.
External Submenu
Menu
Description
GPU Device Selection
Opens the GPU Selection menu.
V-Ray DenoiserOpens the V-Ray denoising tool.
VRMesh ViewerOpens the V-Ray Mesh Viewer.
V-Ray Preferences Submenu
MenuDescription
Enscape CompatibilityEnables the support for Enscape materials and assets. When disabled, Enscape data in the scene is ignored.
Reset VFB StateResets the V-Ray Frame Buffer settings and position to the defaults.
V-Ray Help Submenu
This submenu contains shortcuts for additional V-Ray Help.
Menu
Description
Brings you to the Chaos Group Online help site.
About V-Ray
Shows you information about the installed version. It also include information about the EULA and Copyright notices.
License
Allows you to open the Online license server and to release your license.
Release V-Ray LicenseReleases all V-Ray Licenses.
License ServerLoads the V-Ray Online License Server configuration page in the web browser.
Footnotes
  1. With V-Ray 5 for Rhino, the Zip file created via the Pack Project option includes not only the project file and its V-Ray associated assets but also all native Rhino bitmap textures used in the project file.
  2.  When you use the Pack Project option, a pop-up message appears that asks you whether or not to pack Cosmos asset files with the project.
  3.  The 'Set Material ID Colors to Black' option is removed from the V-Ray menu, but this workflow is still possible when using the command _vraySetMtlID.
