Square Enix © Goodbye Kansas
« Previous Version 11 Next »
This page provides information on the V-Ray Shelf.
V-Ray includes a shelf with easy shortcuts to some of the most commonly used V-Ray components.The shelf can be enabled from the Settings tab of the Render Settings window.
Shelf Functions
The V-Ray Shelf provides the functions listed below. Note that all buttons check if V-Ray (or respectively IPR) is the current renderer, and if not, will prompt you to set the renderer to V-Ray.
ButtonDescription
Create a VRayProxy File Formats from the selected object
Load  VRayProxy File Formats
Open the V-Ray Scene Manager
Right click to create from V-Ray plugin
No left click functionality.
Import V-Ray Material from file
Open the VRmat Converter
Create a Stereo 3D Camera  from the selected camera
Create VRayMetaball
Create VRayVolumeGrid
Create VRayPlane
Create VRaySphereFadeVolume
Create Toon Rendering Attributes | VRayToon
Right click to access additional Toon node(s) selection options.
Create VRayLightMeter
Create V-Ray Clipper
Right click to access additional Clipper node(s) selection options.
Right click to assign V-Ray Object properties to a selection
Left click to create an empty vrayObjectProperties node. Alternatively, adds a single node to all selected objects.
Right click to assign mesh light properties to selection.
Left click to create an empty vrayLightMeshProperties node. Alternatively, adds a single node to all selected objects.
Right click to assign Procedural Fur | VRayFur
Left click to create an empty vrayFurProperties node. Alternatively, adds a single node to all selected objects.
Right click to assign V-Ray Displacement
Left click to create an empty vrayDisplacement node. Alternatively, adds a single node to all selected objects.
Right click to Assign Renderable Curves Attributes
Left click to create an empty vrayRenderableCurve node. Alternatively, adds a single node to all selected objects.
Right click to assign V-Ray NURBS Tessellation attributes.
Left click to create an empty vrayNURBSTesselation node. Alternatively, adds a single node to all selected objects.
Create a VRayLightDome
Create a VRayLightRect
Create a VRayLightSphere
Create a Photometric Light | VRayIES
Create a V-Ray Sun and V-Ray Sky system
Right click to access Select and Delete sun node options
Create a V-Ray Sky Texture
Right click to access Select and Delete sky node options
Create a new VRayMtl and Assign it to the selected objects
Right click to create V-Ray Materials and assign them to the selected objects
Right click to assign V-Ray Bake Options
Left click to create an empty vrayBakeOptions node. Alternatively, adds a single node to all selected objects.
Open the V-Ray Virtual Frame Buffer (VFB)
Right click to reset the V-Ray VFB position. Also provides the option to toggle the Use V-Ray VFB option, which enables V-Ray to render the images in the V-Ray Frame Buffer.
Open the V-Ray Light Lister window
Render with Chaos Cloud.
Open the V-Ray Documentation Website
