« Previous Version 77 Next »
Chaos Vantage, v2.7.1
Official Release
Date - March 13, 2025
New Features
Scatter
  • Support for custom density texture, for the Chaos Scatter, which is using an UV channel different than 1.
Output
Modified
Camera
  • Orthographic views/cameras now match V-Ray.
  • Improved the rendering and UI of the Lens distortion with ST maps.
Fixes
Output
  • Crash when increasing or decreasing the render resolution with 2 GPUs.
  • Missing Render Elements in EXR for render queue items.
Hardware
  • Wrong duplication of render devices, caused by virtual display adapters.
Textures
  • V-Ray Dirt texture not rendering with an empty inclusive "Affected by" list.
  • Default_color from TexUserColor not being used if the object has no UV sets.
UI/UX
  • Wrong wrapping of Geolocation and Animated Geolocation UI spinner values.
DLSS
  • Artifacts from super bright spots in DLSS 4.
Camera
  • Crash when deleting group with its cameras while they are in the animation track.
  • Cameras remain in Scene outliner after camera group deletion.
Chaos Vantage, v2.7.0
Official Release
Date - February 12, 2025
New Features
Scatter
Textures
  • Support for V-Ray Dirt texture.
Sky
Camera
Color management
Output
Color corrections
UI/UX
Modified
DLSS
  • Upgraded DLSS Ray Reconstruction to version 4.
UI/UX
Water surface
  • Improved the accuracy of water surface swell (wind speed) when using different scene units.
Fixes
Materials
  • Emissive layers from SketchUp/Rhino/Revit not rendering.
Camera
  • Camera types other than Perspective not working in 2.6.2.
  • Bloom threshold not working properly when using physical camera exposure.
  • Live Link animation rendering hanging randomly after first frame.
  • Camera thumbnails reset to black when navigating in DCC during Live Link.
  • V-Ray Fur rendering in Vantage during Live Link from SketchUp despite being disabled.
  • Renaming a camera in Vantage results in a new camera when in Live Link.
Geometry
  • Crash when playing animation after deleting an animated procedural object loaded from a .vrscene.
  • Alembic UV channels/sets being ignored if they reused the main topology channel.
Sky
  • Gray dot artifact at the zenith when using most sky models.
UI/UX
  • Missing HDR display options in 2.6.2.
  • Stored window position failing to restore properly on startup.
  • Inconsistent undo action when renaming objects in Scene Outliner.
  • Slow responsiveness of Water Surface object when High Detail is enabled.
Rendering
  • Random colored pixels when a mesh has three or more UV channels/sets with some unused.
  • Random colored pixels with Alembic files with more than one UV set and more than one object/voxel.
Chaos Vantage, v2.6.2
Official Release
Date - November 28, 2024
New Features
Texture
Modified
UI/UX
  • Added object and material presets in the Water Surface object.
  • Improved asset import - when dragging onto empty space, an implicit plane at height 0 is used for placement instead of the scene origin.
Fixes
Camera
  • The selected scene animation camera not being saved in the config file.
  • Camera properties not getting reset when opening a new empty scene.
  • Overriding of the camera parameters when choosing a camera type for offline sequence rendering.
  • Camera from the scene track being used in animation instead of the one from the camera animation track.
  • Cameras imported from config file not getting grouped properly.
  • Wrong Aperture Size when choosing a camera in the Vantage Onboarding sample scene.
Live Link
  • Camera not able to be renamed.
  • Incorrect camera creation after it was deleted and moving in the DCC is performed.
  • Material issue with imported multi-material Cosmos assets when adding a V-Ray Light.
  • Displacement not regenerating in Live Link animation rendering
Displacement
  • Crash when attempting to tessellate a very large mesh
Clipper
  • Wrong rendering of Mesh clipper with SSS
  • Render artifacts with clipper mesh and fog start distance
Sun
  • Black sky when the V-Ray 7 PRG sky model is selected. Now it uses the V-Ray 6 model instead in Vantage.
Water surface
  • Wrong wave scale after hiding and showing.
Vantage file
  • Wrong loading of cloned objects with missing parent hierarchy.
Clay mode
  • Clay mode edge texture not being applied to the default material.
Material
  • Incorrect loading of Cosmos 2-sided materials.
  • Incorrect material fog when merging scenes into a "New Scene".
Importing
  • Ignoring the "loop animation" preference option when merging scenes.
  • Wrong orientation of imported .vrscenes from Cinema4D
UI/UX
  • Wrong placement gizmo orientation in Y-up scenes.
Hardware
  • Duplicate devices caused by virtual display adapters.
Wind
  • Wrong vegetation wind animation in Maya and C4D exported scenes.
Scene states
  • Scene state override not getting applied in offline rendering.
  • Non-working scene states when current camera is selected.
Texture
  • Incorrect mip-maps and bump mapping behind semi-transparent objects.
  • Unwanted texture clipping when using stochastic opacity with small values.
Fog
  • Wrong rendering of fog with a start distance behind refractive objects.
Chaos Vantage, v2.6.1
Official Release
Date - October 31, 2024
New Features
Water surface
Texture
  • Added support for vector mode displacement for the Phoenix Ocean Texture.
Render elements
  • Added SSS to the GI render element
Fixes
Vantage file
  • Crash when loading a config file.
Live Link
  • Unwanted camera creation for each camera move during Live Link.
Displacement
  • Crash when attempting to displace a very large mesh.
Material
  • Incorrect opacity rendering for Bitmap or VRayBitmap textures with alpha channels.
Clipper
  • Several shading bugs with Clipper.
Chaos Vantage, v2.6.0
Official Release
Date - October 24, 2024
New Features
Material
Clipper
Water surface
Virtual Reality
Camera
UI/UX
  • Added import camera, light and material buttons in Camera, Lights and Materials tab respectively.
Clay mode
Texture
  • Support for PhoenixFDOcean texture.
  • Support for V-Ray Water Texture in Maya, SketchUp, Rhino and Revit.
Chaos Cosmos
  • Support for Cosmos multi-asset selection and import.
Multi GPU
  • Added support for Light Cache on multiple GPUs.
Modified
Material
  • Improved Thin-walled - now it works with SSS translucency mode of V-Ray material.
UI/UX
  • Added object type specifier icons to the Scene outliner.
  • Improved opacity - now clip opacity is enabled by default.
  • Improved soft ranges of UI sliders to be readjusting based on type-in input.
  • Improved the text elision in dropdown boxes.
  • Improved the Home Screen - now it doesn't appear when starting a Live Link session and Vantage is not started.
Tools
  • Improved Move Pivot tool to respect the local/world coordinate space toggle.
Scene states
  • Improved the interpolation of scene states when NONE is used - now NONE is skipped when calculating state interpolation.
Clouds
  • Improved the rendering of clouds when using DLSS, at large upscale ratios the flickering is greatly reduced.
Color corrections
  • Improved the Bloom post effect to better match round shapes.
Multi GPU
  • Improved the multi-GPU offline rendering speed with compositing elements.
Fixes
Virtual Reality
  • Washed out colors on Virtual Reality headsets.
Chaos Cosmos
  • Blur on newer Cosmos animated assets.
UI/UX
  • Wrong undo action when renaming objects in the Scene outliner.
  • Long Home Screen delay when loading DropBox scene thumbnails.
  • Inconsistency in display selection on startup.
Rendering
  • Black pixels caused by weighted firefly filter in rare cases.
Importing
  • Mismatch of timing of deformed and animated transformed objects when .vrscene is imported instead of opened.
  • Wrong loading of Anima textures at arbitrary frames when .vrscene is imported instead of opened.
Render devices
  • Device selection regression introduced in 2.5.2.
Importing
  • Wrong point light intensity when using Lumens or Watts.
Chaos Vantage, v2.5.2
Official Release
Date - September 12, 2024
Modified
Geometry
  • Semi-transparent objects after multiple bounces now do not render black.
UI/UX
  • In Color corrections tab Highlight burn option now is available when Filmic tonemap is enabled.
Fixes
UI/UX
  • UI input spinboxes are cutoff for sun geolocation and animated geolocation properties.
  • Floating settings dialog getting stuck to the cursor when the label is clicked.
  • Crash while downloading sample scenes.
  • Crash when a non-Custom offline render preset is restored from INI file.
  • Crash on Intel GPUs when responsive desktop is turned on.
  • Some shortcuts not working on startup
Camera
  • Wrong skipping of the first camera when importing/merging a .vrscene.
Scatter
  • Crash with scatter using edited instances from Max.
  • Disappearing deforming instances used in Chaos Scatter.
Rendering
  • Unrecognized color spaces (scene-linear Rec.709-sRGB) treated as raw when loading textures.
  • Motion blur not rendering since 2.5.0.
  • Render artifacts with bump/normal maps using named or non-default UV sets also used by other textures.
Geometry
  • Hair rendering on Intel GPUs.
  • Wrong displacement normals when the base object is scaled in Maya.
  • Animated object visibility not working with decals.
Environment
  • Rendering with large HDRI texture on AMD and Intel GPUs.
Material
  • Vertical flip not working in UVW transformation for Opacity map.
Chaos Vantage, v2.5.1
Official Release
Date - July 11, 2024
Modified
Geometry
  • Cloned animated deforming objects now keep the source mesh animation.
Fixes
Virtual Reality
  • Vantage crashes on startup when SteamVR is set as OpenXR runtime .
Fur
  • Interactive update of a material on fur objects while dragging and dropping.
Chaos Vantage, v2.5.0
Official Release
Date - June 2, 2024
New Features
Virtual Reality
Chaos Vantage is compatible with all VR headsets (tested with Meta Quest 2, Meta Quest Pro, Meta Quest 3, HTC Vive, and Varjo Aero). Wireless connection is supported, but for smooth performance a tethered connection is recommended. Ensure an appropriate OpenXR runtime is set in the VR's respective app:
  • Windows Mixed Reality: "Mixed Reality Portal" > "Settings" > "Set up OpenXR".
  • Oculus: "Oculus" app > "Settings" > "General" > "Set Oculus as Active".
  • SteamVR: "SteamVR" app > "Settings" > "Developer" > "Set SteamVR as OpenXR Runtime
Animation
Materials
  • Support for VRayEdgesTex in bump and rounded corners.
Geometry
  • Support for animated partial object visibility.
Rendering
UI/UX
Color Corrections
  • Loading chromatic aberration from VFB settings in .vrscene.
Modified
Decals
  • Added decal option to lock the width/length ratio.
  • Improved the "place decals" tool to be activated when importing or dragging decals from the Chaos Cosmos browser and to load the decal properties.
UI/UX
  • Improved the "Always on top" behavior, now it is disabled while HQ rendering.
  • Improved UI - now distance parameters display with scene units.
  • Improved the camera settings layout.
  • Improved the highlighting and selection in scenes with millions of instances.
Environment
Performance
  • Texture loading speed is now 5-10% faster.
  • Improved acceleration structure rebuilds and instance updates for better performance.
Vantage file
  • Merged assets as a result of "Open file as config only" now are properly saved in the .vantage file.
Installer
  • New default install directory is C:\Program Files\Chaos\Vantage\. For versions prior to Chaos Vantage 2.5, the default location is - C:\Program Files\Chaos Group\Vantage\
Fixes
Environment
  • Visible strip artifacts on clouds.
  • Incorrect environment rotation when using the "Flipped" option in Maya
Decals
  • Decals not rendering from Live Link from Revit or other V-Ray 6.1 builds.
  • Decals not updating on animated objects under specific circumstances.
  • Transform animation from .vrscene being ignored for decals.
Textures
  • Incorrect saturation of textures when dynamic textures are enabled.
  • Reduced checker artifacts with UVWRandomizer random rotation and certain normal maps when dynamic textures are enabled.
UI/UX
  • Overlay issue when using multiple GPUs with OptiX or DLSS upscaling.
  • Incorrect change of the "View mode" after "Frame Selected/Scene" action.
  • Hiding of the "Create scene state" dialog when "Always on top" option is enabled.
  • Undo transformation for objects in very large scenes.
  • Non-functioning undo shortcut while the Transform Dialog is open.
Vantage file
  • Generation of additional clone objects when opening the scene as config only.0
Chaos Vantage, v2.4.0
Official Release
Date - May 21, 2024
New Features
Geometry
Materials
  • Support for "Thin walled" option in V-Ray material.
Textures
  • Support for UDIM textures.
Color corrections
Camera
  • Support for setting "Auto-exposure" and "exposure bias" from .vrscene or Live-link.
Lights
  • Support for dome light "horizontal flip" option from Maya.
UI/UX
Animation editor
Modified
Geometry
  • Improved Scatter generation and update for detailed target and area include/exclude meshes.
  • Improved denoising of deforming geometry.
UI/UX
  • Scatter and fur objects can now be selected in the viewport.
  • Improved tooltips timing.
Denoiser
  • Updated DLSS-RR to version 3.7.
Performance
  • Improved playback performance with a small number of animated instances and a large number of non-animated instances.
  • Improved dynamic textures update performance.
Fixes
Geometry
  • Merging of animated scenes with different Up vector results in wrong orientation.
Chaos Cosmos
  • Wrong rendering of Cosmos assets exported from Maya.
UI/UX
  • Crash when modifying key shortcuts.
  • Disappearing popup dialogs for camera settings.
  • Hiding an object doesn't hide its descendants if they are procedural objects (scatter, fur, light).
  • NVENC failure when falling back from AV1 to H264 on older GPUs.
Installer
  • Installer doesn't proceed when there is no V-Ray License Service installed.
Chaos Vantage, v2.3.0
Official Release
Date - March 27, 2024
New Features
Materials
  • Support for rendering V-Ray Blend Material (BRDFLayered).
Render element
UI/UX
Output
Modified
Displacement
  • Improved memory used for displacement by varying tessellation level within a mesh.
Denoiser
  • Updated Intel Open Image Denoise to version 2.2.
Light Cache
  • Improved Light Cache to slightly better preserve low intensity samples.
UI/UX
  • Chaos Cosmos Browser UI responsiveness.
Fixes
Displacement
  • Random displacement when using unsupported secondary UV channel of the geometry object.
Scene states
  • Broken sub-states after dropping Environment texture.
Live Link
  • Wrong Live Link update for Nodes with unsupported materials.
  • Wrong rendering of Glossy Refraction with rotated texture during Live Link with Rhinoл
Lights
  • Sun azimuth rotation values to match geographical azimuth. Old saved .vantage files will be automatically updated to use new values on Save.
Collision
  • Missing "Height ratio" update when collision "Height tolerance" is changed.
Clouds
  • Wrong cloud shading with sun slightly under the horizon.
Lighting
  • Wrong lighting when rendering using direct light reservoir resampling and the scene contains a normal map.
  • Refraction artifacts when rendering with direct light reservoir resampling.
UI/UX
  • Disappearing toolbar in the Debug Log window after second opening.
  • Hiding of the HQ rendering dialog while "Always on top" is enabled.
Denoiser
  • Streak artifacts with Optix denoiser and multi GPU setup.
  • Broken temporal (“reduce flickering”) denoising in multi GPU mode.
Chaos Vantage, v2.2.3
Official Release
Date - February 21, 2024
New Features
Chaos Scatter
  • Support for scattering lights.
  • Support for VRayMultiSubTex.
Modified
Geometry
  • Improved loading speed of .vrscenes with a small number of very detailed meshes.
Fixes
Geometry
  • Slow mesh loading in Chaos Vantage 2.2.2.
Material
  • Crash when a texture is set as bump amount in a material.
Live Link
  • Artifacts on Chaos Scatter instances after changing the material of their source model.
  • Missing sun properties in Chaos Vantage during Live Link in version 2.2.2. Now sun properties are available only when the scene in the host app does not contain a sun light.
  • Incorrect lighting when an object is turned into mesh light during.
Camera
  • Resetting of "Aperture size" when reopening a scene.
Animation editor
  • Animation trim not taken into account in the Render setup dialog.
Chaos Vantage, v2.2.2
Official Release
Date - February 8, 2024
New Features
Chaos Scatter
Modified
Camera
  • Improved camera imported from SketchUp - now view matches when using Two-Point Perspective.
  • increased camera limit from 100 to 1000.
  • Now Field of view does not change between cameras with different focus distance when Lens mode is set to Field of View.
  • Film Gate and Zoom settings are now hidden when Lens mode is Field of View.
Environment
  • Improved physical sky responsiveness.
Fixes
Denoiser
  • Brightness flicker issue when using a combination of DLSS Ray Reconstruction as Primary and NVidia Optix AI as Secondary denoisers
  • Ghosting in offline camera animation with Optix denoiser
  • DLSS preset not getting restored properly on Vantage startup
  • Motion blur not working with the DLSS modes that have upscaling different from 2x
  • Artifacts with "only final pass" denoising
Camera
  • Crash caused by reordering cameras in Camera lister.
  • Crash caused by leveling camera and then saving .vantage file.
Scene states
  • Crash when using sub state with deleted objects.
Displacement
  • Geometry gaps when using stochastic tiling and displacement.
  • Wrong displacement amount caused by object scaling.
Live Link
  • Wrong update of V-Ray Light mesh.
  • Flipped instanced geometries during Render animation with Chaos Vantage from Cinema 4D.
Chaos Cosmos
  • Slow scene load when download of missing Cosmos assets is canceled.
Scattering fog
  • Incorrect GI caused by Scatter fog with "affect secondary" on and "scatter GI" off.
UX/UI
  • Wrong size of checkbox size on high dpi displays.
Chaos Vantage, v2.2.1
Official Release
Date - December 15, 2023
New Features
Geometry
  • Support for material ID for displacement.
Fixes
Geometry
  • Crash with mesh file with thousands of voxels.
  • Displacement UV scale issue in SketchUp.
  • Crash with empty geometry with added displacement.
  • Broken displacement continuity with SketchUp scenes.
Materials
  • Clay mode removing displacement.
  • Clay mode removing light textures.
Live Link
  • Crash with animated ForestPro objects in 3Ds Max Live Link.
Chaos Vantage, v2.2.0
Official Release
Date - December 7, 2023
New Features
Geometry
  • Support for V-Ray Fur, Ornatrix, Hairfarm, and XGen hair.
  • Support for V-Ray Displacement.
  • Support for new V-Ray 6.2  Forest pack and Rail clone instancing.
Materials
  • Support for V-Ray Hair Next material.
Hardware
  • Support for Intel Meteor Lake iGPU.
Batch rendering
  • Render Setup options and render queue items are now stored in the .vantage file.
Live Link
UI/UX
  • Implemented a warning and error count indicator in the status bar.
Rendering
Modified
Geometry
  • Improved GPU peak memory usage when loading the geometry for a scene.
  • Improved check for failed geometry allocations.
DLSS
  • Improved DLSS - added 2.25x and 3x upscale modes (available when Secondary (when static) denoiser is set to Same as Primary).
  • Reduced memory usage.
Denoiser
Scene States
  • Properly update the Scene States helper message on undo/redo.
  • Update scene state button now creates necessary sub-states if ORIGINAL SCENE or SAVED SCENE is currently chosen.
  • Detected changes for scene states when modifying a New file.
Navigation
  • Improved Orthographic camera navigation. Now Navigate around cursor ray hit and Navigate around selection work properly.
UX/UI
  • Improved Viewport Fill - now filter is disabled when sharpness is set to 0.
  • Improved DPI scaling on 150% and similar ratios.
Fixes
Geometry
  • Crash when loading invalid Instancer2 with missing node reference.
UI/UX
  • Bug with wrong UI slider ranges.
  • Wrong trimming of the scene animation track.
  • Auto-exposure and noise mask overlay while using Intel GPUs for rendering.
  • Wrong reloading of a saved .vantage file, with imported .vrscene.
  • Animated cameras from imported vrscenes are not loaded with animation after reload of .vantage file.
  • Wrong camera grouping on import.
Textures
  • Missing texture UVs if their UVW generator is missing.
Output
  • Wrong baking of Exposure bias in EXR when exposure correction is disabled.
  • Camera white balance not getting saved in EXR.
Chaos Vantage, v2.1.1
Official Release
Date - October 10, 2023
New Features
View modes
UI/UX
  • Implemented status messages Info, Modified, Created, Switched for sub-states and scene states.
Modified
Textures
  • Support for mix_amount parameter for 3ds Max's Composite texture.
Fixes
  • Sequence from animated camera in Vantage not rendering when in Live Link.
Installation
  • Possible crash after downgrading Vantage.
Scene States
  • Incorrect Undo action on moved objects after applied scene state.
Chaos Vantage, v2.1.0
Official Release
Date - September 21, 2023
New Features
DLSS
Material
  • Support for refraction glossiness.
Hardware
  • Support for discrete Intel Arc GPUs (experimental).
Modified
Batch rendering
  • Render queue items are now stored between offline rendering sessions.
UI/UX
  • Camera thumbnail now updates automatically when scene states are changed for the camera.
Fixes
UI/UX
  • Crash when clicking the new version notification button in the menu bar.
  • Incorrect render resolution settings when adding multiple cameras using the Group enqueue mode and the <from camera> resolution preset.
Scene States
  • Incorrect NONE sub-state for Objects and Materials
  • Incorrect camera scene state in the camera scene states dropdown menu when editing render queue item.
Chaos Vantage, v2.0.1
Official Release
Date - August 03, 2023
New Features
Scene states
  • Smooth transition between scene states attached to cameras in the animation timeline.
Rendering
Textures
  • Support for Bercon tiles texture.
Animation editor
Auto-exposure
Modified
UX/UI
  • Improved the 'Update textures and meshes for current frame' button - now it is a toggle and when enabled automatically updates meshes and animated textures in the interactive viewport, when playback is not active.
  • Rearranged the rollouts in the Environment tab UI. Renamed Environment rollout to Sky, Cloud settings rollout to Clouds, Sun light rollout to Sun.
  • Moved Sky model settings from Sun rollout to Sky rollout, visible only when Environment mode is Physical sky.
  • The render progress dialog is now movable.
Performance
  • Improved memory usage when using a single GPU (around 30MB per megapixel) to not use double buffering.
Scene states
  • Renamed '<chosen scene state>' to '<current scene state>' in sequence rendering, keeping current changes during the offline rendering.
  • Added a SAVED SCENE state, updated on each "Save scene" or "Save Scene As..." action, preventing the previous accumulation of Auto Saved sub-states.
  • Improved the 'Create scene state' button - now it automatically creates all necessary sub-states where needed and is added in the top toolbar.
  • Renamed the 'DEFAULT' scene state to be 'ORIGINAL SCENE'
Output
  • Improved the output filename when Render elements are enabled in sequence rendering to be better recognized by external applications.
Gizmos
  • Improved the rendering of the navigation and placement helper objects.
Fixes
Batch rendering
  • Crash when updating Render queue cameras that to have same output file name.
Cloning
  • Crash when cloning scene objects multiple times.
Scene States
  • Crash when renaming a scene state to a specific name.
  • Missing scene state button in the camera widget when the scene is opened as a config only.
Live Link
  • Crash when opening home screen during Live Link. Now the 'Home sceen' button is disabled during Live Link.
  • Wrong overwriting of the -linkPort console argument by the INI file.
Denoiser
  • Crash when rendering high quality images/sequence with Intel denoiser selected but disabled.
  • Wrong results when rendering on AMD GPUs.
  • Missing denoiser when rendering with 'Only final pass' and pressing 'Stop and Save'.
  • Bug with the denoiser when rendering high quality images/sequences with dynamic textures.
  • Bug with NVIDIA AI temporal upscaling denoising in offline mode.
Lights
  • Wrong loading of mesh lights from vrscenes exported from SketchUp/Rhino/Revit.
Render elements
  • Wrong Normal render element, when "Scattering fog" and "scatter gi" are enabled.
  • Alpha not stored in EXR and PNG when using Intel denoiser or 'Separate files' is enabled. Now Alpha is always generated.
UX/UI
  • Frame scene/selection when using Orthographic camera.
  • Cinemascope resolution presets.
  • Wrong cropping of the light names in the UI.
Geometry
  • Double applying of the VRayScene transformation for Instance objects within a VRayScene.
  • Wrong rendering of imported VRayScene in C4D
Tools
  • “Export static scene” and0 “Export animated scene to Chaos Vantage” now work regardless of V-Ray render engine type in 3ds Max.
Motion blur
  • Motion blur not applied to whole image when using an upscaler.
Chaos Cosmos
  • Wrong redirection for the Cosmos login page.
Camera
  • Fixed the camera position in new empty scene.
  • Strange roll when switching cameras in specific scene.
Chaos Vantage, v2.0.0
Official Release
Date - June 27, 2023
New Features
Scene States
Render Elements
Fog
Textures
  • Support for multiple UV channels.
  • Support for Vertex Color.
  • Support for all options of the Advanced mode of the Color Correction texture from 3ds Max.
  • Support for repeat/offset U/V for UVWGenMaya when not using shading graphs (e.g. for bump maps).
Animation
  • Support for .vrscene file with animated: vertices, vrmeshes, materials, textures and UV parameters, light parameters.
  • Support for animations outside the imported .vrscene range.
Denoiser
Performance
Chaos Scatter
Hardware
  • Support for HDR displays.
  • Support for AMD GPUs (experimental).
Subdivision
  • Support for statically subdivided geometry objects from .vrscene.
Lights
Materials
  • Support for VRmat materials.
  • Support for V-Ray override material (MtlOverride).
UI/UX
  • Helper onscreen text for gizmo manipulators.
  • Rendering quality presets slider with 4 predefined  presets.
Cloning
  • Implemented object cloning functionality with Ctrl+D.
Camera
Tools
Home Screen
Rendering
Geometry
  • Support for embedded vrscene nodes (VRayScene).
Modified
UX/UI
  • Revamped user interface and user experience with reorganized and regrouped parameters.
Fixes
Live Link
  • Double frame sequence rendering during Live Link with 'Render animation with Chaos Vantage'.
Geometry
  • Wrong placement of meshes at the origin when instanced by an Instancer in an animated .vrscene file.
  • Artifacts near the scene origin caused by self intersection.
