This page provides information on the V-Ray menu integrated in Maya's main toolbar.
V-Ray includes a menu with easy shortcuts to some of the most commonly used V-Ray components.
The menu consists of three sections: the first one displays the V-Ray VFB and submits render jobs to Chaos Cloud; the second one offers quick access to commonly used options in V-Ray for Maya; and the third section covers the help functions in V-Ray for Maya.
V-Ray Menu
Menu | Description |
Show V-Ray VFB | Opens the New V-Ray Frame Buffer. |
Render in Chaos Cloud | Opens the Submit to Chaos Cloud window, where you can submit your job and render it in Chaos Cloud. |
Lights | Opens the V-Ray Lights submenu. |
Create V-Ray Proxy | Creates a V-Ray Proxy object. |
Import V-Ray Proxy | Imports a V-Ray Proxy object into the scene. |
V-Ray Scene | Opens the V-Ray Scene Manager. |
V-Ray Object Properties | Opens the VRayObjectProperties submenu where you can: - Apply multiple object properties nodes to selection - Apply single object properties nodes to selection - Remove object properties from selection - Remove object properties from selection and sub-hierarchy - Force create object properties node |
V-Ray Displacement | Opens the VRayDisplacement submenu where you can: - Apply multiple VRayDisplacement to selection - Apply single VRayDisplacement node to selection - Remove VRayDisplacement from selection - Remove VRayDisplacement from selection and sub-hierarchy - Force create VRayDisplacement node |
V-Ray Fur | Opens the VRayFur submenu where you can: - Add VRayFur to selection (works for meshes only) - Remove VRayFur from selection - Remove VRayFur from selection and sub-hierarchy - Force create VRayFur properties node. |
V-Ray Clipper | Creates a VRayClipper. |
V-Ray Plane | Creates a procedural infinite-plane primitive for V-Ray. |
V-Ray Sphere Fade | Creates a VRaySphereFadeVolume that renders just small parts of the scene by putting them in a special spherical locator. |
V-Ray Toon | Creates a VRayToon node that produces cartoon-style outlines on objects in the scene. |
V-Ray Volume Grid | Creates a VRayVolumeGrid node. |
V-Ray Bake Options | Opens the V-Ray Bake Options submenu where you can: - Assign single V-Ray bake options to selection - Assign multiple V-Ray bake options to selection - Remove V-Ray bake options from selection - Remove V-Ray bake options from selection and sub-hierarchy - Force create VRayBakeOptions properties node - Show default V-Ray bake options - Bake with V-Ray... |
V-Ray Renderable Curves | Opens the VRayRenderableCurves submenu where you can: - Apply multiple VRayRenderableCurve to selection - Apply single VRayRenderableCurve node to selection - Remove VRayRenderableCurve from selection. - Remove VRayRenderableCurve from selection and sub-hierarchy - Force create VRayRenderableCurve properties node |
V-Ray Metaball | Creates a VRayMetalball. |
V-Ray NURBS Tessellation | Opens the VRayNURBSTessellation submenu where you can: - Apply multiple VRayNURBSTessellation to selection - Apply single VRayNURBSTessellation to selection - Remove VRayNURBSTessellation from selection. - Remove VRayNURBSTessellation from selection and sub-hierarchy - Force create VRayNURBSTessellation properties node |
Tools | Opens the V-Ray Tools submenu. |
Help | Opens the Help submenu. |
About Chaos V-Ray | Opens the About window. |
V-Ray Rect Light | Creates a VRayLightRect, also known as Area Light. |
V-Ray Dome Light | Creates a VRayLightDome. |
V-Ray Sun | Creates a VRaySun. |
V-Ray Sky | Creates a VRaySky. |
V-Ray Sphere Light | Creates a VRayLightSphere. |
V-Ray Mesh Light | Opens a VRayLightMesh submenu where you can: - Turn selection into lights (works for meshes only) - Turn selection into lights (apply single VRayLightMesh) - Remove light modifiers from selection - Remove light modifier from selection and sub-hierarchy - Force create VRayLightMesh properties node. |
V-Ray IES Light | Creates a VRayIES. |
V-Ray Light Lister | Opens the V-Ray Light Lister window. |
V-Ray Light Meter | Creates a VRayLightMeter node. |
V-Ray Tools submenu
Create V-Ray PluginNode | Opens the V-Ray plugin submenu where you can create: - Texture |
Import V-Ray Material from File | Opens the V-Ray Material Importer dialog. |
V-Ray Stereo Rig | Creates a V-Ray Stereo Rig. |
V-Ray VRmat Converter | Opens the VRmat Converter. |
Archive V-Ray Scene | Opens the Archive V-Ray Scene window where you can export a .vrscene package archive with all asset files. |
Convert to New VRayProxy Node | Converts old V-Ray Proxy objects (VRayMesh) to the new VRayProxy node. |
Convert Scene from V-Ray | Opens the Convert Scene for V-Ray window where you can convert a material to a VRayMtl. |
Migrate Legacy Scenes | Opens the Migrate Legacy Scenes window, which migrates features that are deprecated and not fully compatible with V-Ray 5. |
Opacity Cutout | Opens the Opacity Cutout window, which converts low-poly opacity mapped objects to actual geometry cutouts. |
V-Ray Material Library Browser | Opens the V-Ray Material Library Browser. |
Help submenu
Tutorials | Opens the Tutorials page of the V-Ray for Maya online documentation. |
Documentation | Opens the V-Ray for Maya online documentation. |
About Chaos V-Ray
Provides information about the V-Ray version, that can be copied. It also provides copyright information and links to Chaos website and documentation.
