Square Enix © Goodbye Kansas
« Previous Version 18 Next »
This page provides information on the V-Ray menu integrated in Maya's main toolbar.
V-Ray includes a menu with easy shortcuts to some of the most commonly used V-Ray components.
The menu consists of three sections: the first one displays the V-Ray VFB and submits render jobs to Chaos Cloud; the second one offers quick access to commonly used options in V-Ray for Maya; and the third section covers the help functions in V-Ray for Maya.
V-Ray Menu
MenuDescription
Show V-Ray VFBOpens the V-Ray Frame Buffer.
Submit to Chaos CloudOpens the Submit to Chaos Cloud window, where you can submit your job and render it in Chaos Cloud.
Chaos Cosmos BrowserOpens Chaos Cosmos Browser, where you can find various assets ready for use.
V-Ray Material Library BrowserOpens the V-Ray Material Library Browser if it is downloaded in advance with an earlier V-Ray version. If the V-Ray Material Library folder is empty, opens the Chaos Cosmos Browser instead.
Live-Link to Chaos VantageInitiates a Live-Link to Chaos Vantage.
LightsOpens the V-Ray Lights submenu.
Create V-Ray ProxyCreates a V-Ray Proxy object.
Import V-Ray ProxyImports a V-Ray Proxy object into the scene.
V-Ray SceneOpens the V-Ray Scene Manager.
V-Ray Object Properties
Opens the VRayObjectProperties submenu where you can:
- Apply multiple object properties nodes to selection
- Apply single object properties nodes to selection
- Remove object properties from selection
- Remove object properties from selection and sub-hierarchy
- Force create object properties node
V-Ray Displacement
Opens the VRayDisplacement submenu where you can:
- Apply multiple VRayDisplacement to selection
- Apply single VRayDisplacement node to selection
- Remove VRayDisplacement from selection
- Remove VRayDisplacement from selection and sub-hierarchy
- Force create VRayDisplacement node
V-Ray Fur
Opens the VRayFur submenu where you can:
- Add VRayFur to selection (works for meshes only)
- Remove VRayFur from selection
- Remove VRayFur from selection and sub-hierarchy
- Force create VRayFur properties node.
V-Ray ClipperCreates a VRayClipper.
V-Ray DecalCreates VRayDecal.
V-Ray EnmeshCreates V-Ray Enmesh.
V-Ray PlaneCreates a procedural infinite-plane primitive for V-Ray.
V-Ray Sphere FadeCreates a VRaySphereFadeVolume that renders just small parts of the scene by putting them in a special spherical locator.
V-Ray ToonCreates a VRayToon node that produces cartoon-style outlines on objects in the scene.
V-Ray Volume GridCreates a VRayVolumeGrid node.
V-Ray Bake Options
Opens the V-Ray Bake Options submenu where you can:
- Assign single V-Ray bake options to selection
- Assign multiple V-Ray bake options to selection
- Remove V-Ray bake options from selection
- Remove V-Ray bake options from selection and sub-hierarchy
- Force create VRayBakeOptions properties node
- Show default V-Ray bake options
- Bake with V-Ray...
V-Ray Renderable Curves
Opens the VRayRenderableCurves submenu where you can:
- Apply multiple VRayRenderableCurve to selection
- Apply single VRayRenderableCurve node to selection
- Remove VRayRenderableCurve from selection.
- Remove VRayRenderableCurve from selection and sub-hierarchy
- Force create VRayRenderableCurve properties node
V-Ray MetaballCreates a VRayMetalball.
V-Ray NURBS Tessellation
Opens the VRayNURBSTessellation submenu where you can:
- Apply multiple VRayNURBSTessellation to selection
- Apply single VRayNURBSTessellation to selection
- Remove VRayNURBSTessellation from selection.
- Remove VRayNURBSTessellation from selection and sub-hierarchy
- Force create VRayNURBSTessellation properties node
ToolsOpens the V-Ray Tools submenu.
HelpOpens the Help submenu.
About Chaos V-RayOpens the About window.
MenuDescription
V-Ray Rect LightCreates a VRayLightRect, also known as Area Light.
V-Ray Dome LightCreates a VRayLightDome.
V-Ray SunCreates a VRaySun.
V-Ray SkyCreates a VRaySky.
V-Ray Sphere LightCreates a VRayLightSphere.
V-Ray Mesh Light
Opens a VRayLightMesh submenu where you can:
- Turn selection into lights (works for meshes only)
- Turn selection into lights (apply single VRayLightMesh)
- Remove light modifiers from selection
- Remove light modifier from selection and sub-hierarchy
- Force create VRayLightMesh properties node.
V-Ray IES LightCreates a VRayIES.
V-Ray Light ListerOpens the V-Ray Light Lister window.
V-Ray Light MeterCreates a VRayLightMeter node.
V-Ray Tools submenu
MenuDescription
Create V-Ray PluginNode
Opens the V-Ray plugin submenu where you can create:
- Texture
- Float texture
- Light
- Volume shader
- BRDF material
- Material
Import V-Ray Material from FileOpens the V-Ray Material Importer dialog.
V-Ray Stereo RigCreates a V-Ray Stereo Rig.
V-Ray VRmat ConverterOpens the VRmat Converter.
Archive V-Ray SceneOpens the Archive V-Ray Scene window where you can export a .vrscene package archive with all asset files.
Convert to New VRayProxy NodeConverts old V-Ray Proxy objects (VRayMesh) to the new VRayProxy node.
Convert Scene from V-RayOpens the Convert Scene for V-Ray window where you can convert a material to a VRayMtl.
Migrate Legacy ScenesOpens the Migrate Legacy Scenes window, which migrates features that are deprecated and not fully compatible with V-Ray 5.
Opacity CutoutOpens the Opacity Cutout window, which converts low-poly opacity mapped objects to actual geometry cutouts.
Export Materials to USD
Opens the Export Materials to USD window, which allows V-Ray materials to be exported to USD files.
Export Materials to MaterialX
Opens the Export Materials to MaterialX window, which allows V-Ray materials to be exported to .mtlx file.
Check for Missing Cosmos AssetsOpens the Check for Missing Cosmos Assets window, which relocates or downloads missing Cosmos assets.
Help submenu
MenuDescription
TutorialsOpens the Tutorials page of the V-Ray for Maya online documentation.
DocumentationOpens the V-Ray for Maya online documentation.
About Chaos V-Ray
Provides information about the V-Ray version, that can be copied. It also provides copyright information and links to Chaos website and documentation.
