Square Enix © Goodbye Kansas
« Previous Version 23 Next »
This page discusses render elements in general, with links to sub-groups of render elements.
Render Elements are a way to break out renders into their component parts such as diffuse color, reflections, shadows, mattes, etc. This gives fine control over the final image when using compositing or image editing applications to re-assemble the component elements. Render elements are also sometimes known as render passes.
Render elements appear in the V-Ray Frame Buffer (VFB) and can be viewed from the drop-down at the upper left corner of the VFB. They can also be saved out of the VFB as many common file formats.
Render elements are generated at render time based on the user's selection before rendering. Most render elements have parameters that can be customized to further assist the composting process. These parameters are described on each render element's individual page, along with common uses and any notes on their generation and usage.
V-Ray supports the built-in Maya Render Elements User Interface. However, V-Ray provides its own render elements and does not support the standard render elements implemented in Maya. Therefore standard Maya render elements will not work with V-Ray, and vice-versa.
The list of render elements that are supported by V-Ray can be found on the List of Supported Render Elements section below. All render elements support native V-Ray materials. Some render elements also support standard Maya materials, and these are noted on the Supported Render Elements page as well.
When using the V-Ray frame buffer, V-Ray will write render elements only if you specify either one of the V-Ray raw image file outputs or the Separate render channels options. If you want to specify the render elements outputs using the Maya Render Output field or using the output options of the various render elements, then you have to disable the V-Ray frame buffer.
Since V-Ray Next Update 1, some of the render elements are rendered differently than before. The Lighting render element now contains all direct diffuse illumination and the GI element contains all indirect diffuse illumination. Similarly, all direct reflections of lights now go to the Specular element and all indirect reflections go to the Reflection element.
Previously this behavior depended on the sampling of the lights and not just on the type of the contribution. Some of the direct contributions that should be in the Lighting and Specular elements were written to the GI and Reflection elements instead. In both cases they compose back to Beauty correctly but the different types of contributions are now split between the elements more consistently.
This change makes the elements more consistent but it's also needed for preventing artifacts in these elements with the adaptive dome light (and possibly in the future with other adaptive lights).
The raw elements are affected only when the corresponding normal and filter elements are available, otherwise they're rendered as before. This is because the raw elements have to be derived internally from the corresponding normal elements in order to work with the consistent elements (e.g. VRayRawGlobalIllumination = VRayGlobalIllumination / DiffuseFilter).
There's an option to enable or disable the new behavior in the Rendering rollout under the Overrides tab in the Render Settings window. The consistent elements are automatically enabled when the scene contains an adaptive dome light so they don't have artifacts. They are also enabled by default for new scenes. For V-Ray GPU they are always enabled without an option to disable them.
UI Path: ||Display Render Settings button|| > Render Elements tab
Render Elements Sub-groups
Render Elements in V-Ray break down into four major groups:
Beauty Render Elements
The Beauty Render Elements are the primary render elements that form V-Ray's
pre-composited final render pass known as Beauty or RGB Color. These include the
LightingGlobal Illumination, ReflectionRefractionSpecular, etc.
Matte Render Elements
The Matte Render Elements aid selection masking in the compositing process.
These include the Material IDMulti MatteObject ID, and Render ID Render Elements.
Geometry Render Elements
The Geometry Render Elements rely on geometry to generate geometry data for the compositing
process. These include the VelocityZ-Depth, and Normals Render Elements.
Utility Render Elements
The Utility Render Elements give insight into how V-Ray is running and extra functionality for compositing.
These include the Distributed Render IDSample RateDenoiserExtra texture, etc.
The following render elements are supported by V-Ray. All render elements support native V-Ray materials while some render elements support standard Maya materials, as noted in the table below.
In order to render a correct Raw render pass, you need to also render the corresponding main element and filter. For example, Raw Reflection will require you to render Reflection and Reflection filter. For Raw GI, you need GI and Diffuse, etc.
Render elementMaya node nameColor Depth of EXR floating-point channels*Description
Atmospheric Effects
vrayRE_Atmospheric_Effects16bit/32bitAtmospheric effects, such as Environment Fog.
Background
vrayRE_Background16bit/32bitImage background, such as any Background Texture specified in the Environment overrides.
Bump Normals vrayRE_BumpNormals16bit/32bitNormals generated by bump maps, in screen space (which is not the same as camera space). Use the VRaySamplerInfo utility texture node to get the normals in camera, world or object space.
Caustics
vrayRE_Caustics16bit/32bitThe caustics on the material. These caustics are present only when the Caustics option of V-Ray is enabled. This channel does not include GI caustics.
Coat SpecularvrayRE_Coat16bit/32bitDirect surface specular highlights coming from the VRayMtl Coat layer used in the scene.
Coat FiltervrayRE_Coat_Filter16bit/32bitReflection filter for VRayMtl Coat layer.
Coat GlossinessvrayRE_Coat_Glossiness16bit/32bitReturns a float value that corresponds with the Coat Glossiness value of the VRayMtl Coat layer.
Coat ReflectionvrayRE_Coat_Reflection16bit/32bitIndirect reflections coming from the Coat layers of VRayMtl used in the scene.
CoveragevrayRE_Coverage16bit/32bitFor each pixel, the final values for the render element are taken from the object that makes the largest contribution to that pixel.
CryptomattevrayRE_Cryptomatteforced 32bit (for multi-channel files)Uses the Cryptomatte convention by Psypop to encode mattes into multichannel OpenEXRs.
Custom ColorvrayRE_Custom_Color16bit/32bitA generic render element container. Use the Alias value to specify which render element it should be used as.
DR BucketvrayRE_DR_Bucket16bit/32bitIdentifies the render node responsible for rendering a bucket during distributed rendering.
DiffusevrayRE_Diffuse16bit/32bitPure diffuse surface color.
DenoiservrayRE_Denoiser16bit/32bitApplies a denoising operation to the image after it is rendered (with the neccessary channels).
Extra TexturevrayRE_Extra_Texforced 32bit (optional for multi-channel files)Renders the entire scene with a single defined texture mapped on all objects.
Global Illumination (GI)
vrayRE_GI
16bit/32bitThe diffuse surface global illumination. Only present if Global illumination is enabled.
Light Select vrayRE_Light_Select16bit/32bitExtracts the contribution of a user-defined light or a set of lights in the scene as a separate render element.
Light Path ExpressionsvrayRE_Light_Select--A tool for extracting specific lighting events from the scene to a separate channel.
Lighting
vrayRE_Lighting16bit/32bitDiffuse direct surface lighting.
Lightning AnalysisvrayRE_Lightning_Analysis16bit/32bitProvides visual representation of the lighting intensity within a rendered frame.
Material ID vrayRE_Material_IDMaterial ID of scene objects.
Material Select
vrayRE_Material_Select16bit/32bit
Renders only the object(s) assigned to a user-specified V-Ray compatible material. The material can be a top-level material or a sub-material of a VRayBlendMtl.
Matte Shadow vrayRE_Matte_shadow16bit/32bitMatte shadow part of the image.
MetalnessvrayRE_Metalness16bit/32bit
Creates a black and white image, which can be used as a metalness mask when creating PBR shaders.
Multi Matte vrayRE_Multi_Matte16bit/32bitCreates selection masks based on an object ID or material ID.
Multi Matte IDvrayRE_Multi_Matte_ID16bit/32bitReturns an integer value in the image that corresponds to the value of the object's multiMatte ID #.
Noise LevelvrayRE_Noise_Level16bit/32bitCreates a monochromatic image showing the amount of noise in the render.
NormalsvrayRE_Normals16bit/32bitSurface normals in camera space. To output the normals in screen/object/world space, use Maya's Sampler Info utility texture node.
Object ID
vrayRE_Object_IDReturns solid un-shaded colors to represent a numerical identifiers set through that object's Attributes, Object Property, or assigned material. Useful for selection masks. EXRs and .vrimg formats store as integer values.
Object SelectvrayRE_Object_select16bit/32bitRenders only the object(s) called out with a specific Object or Material ID. This effect is reversible to create a render element that excludes a particular object or objects according to Object or Material ID.
Raw Coat FiltervrayRE_Raw_Coat_Filter16bit/32bitCreates a solid mask showing the areas of reflection in the Coat layer without being affected by Fresnel.
Raw Coat ReflectionvrayRE_Raw_Coat_Reflection16bit/32bitPure surface indirect reflection from a VRayMtl Coat layer before it is multiplied by the reflection filter color.
Raw Diffuse FiltervrayRE_Raw_Diffuse_Filter16bit/32bitA solid mask of raw diffuse surface color information not affected by fresnel falloff.
Raw GIvrayRE_Raw_GI16bit/32bitRaw diffuse global illumination (not multiplied by the diffuse surface color). Only present if Global illumination is enabled.
Raw Light
vrayRE_Raw_Light16bit/32bitRaw diffuse direct illumination before it's multiplied by the diffuse surface color.
Raw ReflectionvrayRE_Raw_Reflection16bit/32bitPure surface indirect reflection before it is multiplied by the reflection filter color.
Raw Reflection FiltervrayRE_Raw_Reflection_Filter16bit/32bitA solid mask of raw reflection information not affected by fresnel falloff.
Raw Refraction
vrayRE_Raw_Refraction16bit/32bitPure surface refraction before it is multiplied by the refraction filter color.
Raw Refraction FiltervrayRE_Raw_Refraction_Filter16bit/32bitA solid mask of raw refraction information not affected by fresnel falloff.
Raw ShadowvrayRE_Raw_Shadow16bit/32bitRaw light blocked by other objects.
Raw Sheen FiltervrayRE_Raw_Sheen_Filter16bit/32bitHolds information similar to Sheen Filter RE, but without being affected by Fresnel.
Raw Sheen ReflectionvrayRE_Raw_Sheen_Reflection16bit/32bitPure surface indirect reflection from a VRayMtl Sheen layer before it is multiplied by the reflection filter color.
Raw Total LightvrayRE_Raw_Total_Light16bit/32bitSum of all raw lighting, both direct and indirect.
Reflect IORvrayRE_Reflect_IOR16bit/32bitStores floating-point information that corresponds to the Fresnel IOR values of scene objects' materials.
ReflectionvrayRE_Reflection16bit/32bitAll indirect reflections from a surface.
Reflection Filter vrayRE_Reflection_Filter16bit/32bitReflection filter (the color by which the raw reflections are multiplied to give the final surface reflection). This may be considered an alpha channel for reflections.
Reflection GlossinessvrayRE_Reflection_glossiness16bit/32bitReturns a float value that corresponds with the Reflection Glossiness value of an object's material.
RefractionvrayRE_Refraction16bit/32bitRefractions through a surface.
Refraction Filter vrayRE_Refraction_Filter16bit/32bitThe refraction filter mitigates the raw refraction layer. This render element returns the color by which the raw refractions are multiplied to give the final surface refraction. This may be considered an alpha channel for refractions.
Refraction GlossinessvrayRE_Refraction_glossiness16bit/32bitReturns a float value that corresponds to the Refraction Glossiness value of an object's material.
Render IDvrayRE_Render_IDNode render ID of the object that contributes most to the pixel value.
Render TimevrayRE_Render_Time16bit/32bitShows a floating-point number for each pixel's render time measured in milliseconds.
SSSvrayRE_SSS16bit/32bitRenders just the subsurface part of the VRaySSS2 material on a separate layer.
Sample Rate vrayRE_Sample_Rate16bit/32bitShows an image where the pixel brightness is directly proportional to the number of samples taken at that pixel.
Sampler InfovrayRE_Sampler_Infoforced 32bit (for multi-channel files)Provides information about various aspects of the shaded points - position, normal, bump normal, reflection/refraction vectors and UVW coordinates. Can be used e.g. for world position passes or normal passes.
Self Illumination vrayRE_Self_Illumination16bit/32bitSelf-illumination of the surface.
ShadowvrayRE_Shadow16bit/32bitDiffuse light that is blocked by other objects.
Sheen SpecularvrayRE_Sheen16bit/32bitDirect surface specular highlights coming from the VRayMtl Sheen layer used in the scene.
Sheen FiltervrayRE_Sheen_Filter16bit/32bitReflection filter for VRayMtl Sheen layer.
Sheen GlossinessvrayRE_Sheen_Glossiness16bit/32bitReturns a float value that corresponds with the Sheen Glossiness value of the VRayMtl Sheen layer.
Sheen ReflectionvrayRE_Sheen_Reflection16bit/32bitIndirect reflections coming from the Sheen layer(s) of VRayMtl used in the scene.
SpecularvrayRE_Specular16bit/32bitAll direct specular highlights coming from a surface.
ToonvrayRE_Toon16bit/32bitStores results of V-Ray Toon rendering effect.
Total LightvrayRE_Total_Light16bit/32bitTotal lighting in the scene, both direct and indirect.
Unclamped ColorvrayRE_Unclamped_Color16bit/32bitThe unclamped or adjusted image color before Color Mapping settings are applied.
VelocityvrayRE_Velocity16bit/32bitSurface velocity of an object. This render element is useful for generating motion blur in post-production.
Z-depth vrayRE_Z_depthforced 32bit (for multi-channel files)Z-depth of surfaces in the scene.
* For all image formats except EXR the render elements depend on their respective channels' output settings.
  • V-Ray always anti-aliases with respect to the RGB Color channel. Therefore, other channels may appear jagged or noisy in areas where V-Ray has placed fewer samples.
  • Render elements will render in Distributed Rendering mode.
  • Render elements require additional storage when rendering and thus increase the amount of RAM used during rendering. When rendering to the V-Ray VFB, you can reduce this by rendering directly to a .vrimg file on disk and not storing the final image in memory.
  • Render elements may slow down the final image rendering a little bit, depending on the number of elements that are selected. They have no effect on GI/reflection, etc. calculations.
  • Since V-Ray Next, the Reflection Hilight Glossiness has been removed from the UI as it can no longer be controlled separately from the Reflection Glossiness in VRayMtl. As there will be no difference between the Reflection Hilight Glossiness Render Element and the Reflection Glossiness one, the Reflection Hilight Glossiness Render Element is no longer available.
  • When selecting the Affect All channels option of VRayMtl/VRayToonMtl,  be aware that the information of the respective component will affect all render elements, therefore the Back to Beauty composition will not match the RGB result from the renderer.
